Parallel LCD Display vs. serial LCD, which is best to use with BS2?
Parallax has serial (16 x 2)LCD displays for about $30.00.· I've seen other LCD displays advertised for less money.· I know I'm a cheapskate, but I was wondering if those cheaper displays would be compatable with my BS2?· I've seen some advertised that are parallel displays for about $10.· Will they work with the BS2 ?· Which is better a serial display or parallel?· What is the main difference between the two types?· How do I choose the type of display?· I need to operate my BS2 away from my computer, and I would like to at least be able to debug.
PO2LE
PO2LE
I strongly suggest you get a serial display. It's easier to use. If you want to buy a cheaper display and the company that sells it seems to have good support, by all means do so. Parallax can't really support it. Companies like Scott Edwards Electronics and Matrix Orbital sell a variety of serial LCD displays and have been around for many years. They have a good reputation for support. You'll have to decide on the price and value.
parallel LCD works with the stamp to and it has the code for it to.
parallax http://www.parallax.com/Portals/0/Downloads/src/prod/LCD2x16Par.zip
