What are your cogs doing ? — Parallax Forums
Cluso99Cluso99 Posts: 18,071
edited 2009-01-10 15:58 in Propeller 1
Taking a break, so thought I would let you know what my cogs are doing...
Cog 0 : Launches the RamInterpreter, then launches other cogs, then compares their output and speed
Cog 1 : Runs FullDuplexSerial
Cog 2 : Runs ClusoDebugger (currently pasm but being modified to include spin)
Cog 3 : -free-
Cog 4 : -free-
Cog 5 : Runs the RomInterpreter and a Spin Test routine
Cog 6 : Runs the RamInterpreter and a Spin Test routine (known working version)
Cog 7 : Runs the ClusoInterpreter and a Spin Test routine (this is being debugged)
  • Carl JacobsCarl Jacobs Posts: 41
    edited 2008-09-09 03:26
    I can't resist this one:
    Cog 0 : Runs a supervisory task
    Cog 1 : Runs a variant of FullDuplexSerial
    Cog 2 : Runs an SPI driver for the ENC28J60 ethenet chip
    Cog 3 : Runs an SPI driver for an SD Card
    Cog 4 : Scans 24 analog channels at a rate of 1000Hz per channel
    Cog 5 : Scans 8 digital channels for signals at up to 15kHz per channel
    Cog 6 : Process the changes detected by cog 5.
    Cog 7 : Free, totally free.
    And I've still got 817 longs of memory left!
    This is before the application of JDForth - I'll post a comparison once the code has been converted (About 50% done).
    Carl Jacobs
    JDForth - Forth to Spin Compiler http://www.jacobsdesign.com.au/software/jdforth/jdforth.php
    Includes: FAT16 support for SD cards. Bit-bash Serial at 2M baud. 32-bit floating point maths.·Fib(28) in 0.86 seconds. ~3x faster than spin, ~40% larger than spin.
  • AleAle Posts: 2,363
    edited 2008-09-09 09:22
    I have two props that talk to each other on the same board so:
    Prop1:
    c0: spin, not used after launch
    c1: 320x240 mono LCD refresh (~60 Hz)
    c2: 4 Bit bidi comm to other prop
    c3: bitmap refresh
    c4: oscillator and keyboard scan
    c5: game of life
    c6: not used
    c7: not used
    prop2:
    c0: spin, not used after lauch
    c1: ADC, 500 kSps
    c2: FFT 1024 points
    c3: comm to other prop
    c4-c7: not used
    But most of my projects are just small pieces of assembler code, so I use the simulator.
  • evanhevanh Posts: 17,324
    edited 2008-09-09 09:48
    I should get one :> ... now that I can.
  • SapiehaSapieha Posts: 2,964
    edited 2008-09-09 09:56
    I have 5 proto boards in diferent configurations and diferent COG use.
    And reprogram it very often in my experiments.
    Nothing is impossible, there are only different degrees of difficulty.
    Sapieha
    edited 2008-09-09 10:16
    For my main experiment controller which runs about 4 different pieces of equipment:
    C1: Menu system, data entry, program flow, TV_Text
    C2: TV
    C3: Keyboard
    C4: Motion control
    C5 -C8 Empty so far, plans for a strobe sync
    Graham
  • hippyhippy Posts: 1,981
    edited 2008-09-09 12:43
    0 - LCC VM + LED Flashing C bytecode
    1 - Empty
    2 - Empty
    3 - Empty
    4 - Empty
    5 - Empty
    6 - Empty
    7 - Empty
  • Stephen MoracoStephen Moraco Posts: 476
    edited 2008-09-11 06:04
    Hey, one could do pictures of ...· ;-)
    (now what order did they startup in?)
    -Stephen
    1080 x 801 - 120K
    edited 2009-01-10 09:07
    Time to ask again - what are your cogs doing??
    Prop Tools under Development or Completed (Index)
    http://forums.parallax.com/showthread.php?p=753439
    My cruising website http://www.bluemagic.biz
  • heaterheater Posts: 3,370
    edited 2009-01-10 11:04
    Cluso99 said...
    What are your cogs doing ?"
    Sometimes I'd really like to know !
    Current effort is:
    8080 CPU part 1
    8080 CPU part 2
    8080 CPU part 3
    8080 CPU part 4
    Keyboard
    TV
    SD Card
    Free
    Yep I'm trying to speed up the 8080 emulation by using 4 COGs. Very early stages yet.
  • grasshoppergrasshopper Posts: 438
    0. Main Cog (Eeprom R/W, Commands in/out from USB, Blinks 1/3 LEDs, Checks Errors, 16Bit D/A converter)
    1. FullDuplex
    2. Loops a 16 bit A/D taking 1000+ samples / sec
    3. Math crunching A/D and floating point numbers
    4. PWM a Motor
    Guessing: about 4000 Lines of code in cog"0" alone and 1/2 memory used total all cogs.
