An easy camera to trigger?
Jay Kickliter
Does anyone know of an older (<$70 used on ebay) digital camera that is easy to trigger with a micro-controller? I got an $8 Canon Powershot A510, but even with all the screws out, I just cant get it to come apart. So, are there any cheap cameras that accept an external trigger and don't need to be disassembled? What I really want is a Ricoh, since they can do time lapse, but they're pretty expensive.
http://chdk.wikia.com/wiki/FAQ
I have a nice intervalometer program loaded into my PowerShot 570 using this method. It's a bit tricky to figure out, but works great.
You could explore triggering the camera using the "IR" remote feature. Many low-cost cameras have·provisions for a IR remote. It may not be prety, by you can tape an IR LED to the camera's reciever and then send the correct code.· I know this process is used in some KAP (Kite Arial Photography) kits.
Searider
http://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=39&No=281
You would have to get the FPGA... which is about $150
it saves to an SD card...
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
