cannot debug SX with USB SX-Key — Parallax Forums
Larry MartinLarry Martin Posts: 106
edited 2008-11-21 20:32 in General Discussion
I am having trouble debugging an SX48 with the USB SX-Key and SX-Key v3.2 software. My board debugs ok with my one remaining serial SX-Key and SX-Key v2.02 PC software. The board will also take a Program (^P) from the USB SX-Key, but will not Debug with the new key and software. This happens on more than one board.
The USB SX-Key is rev 1, shipped in June 2008. It is on a USB 1.2 host controller. The system is HP Pavilion running XP Home SP2. I am using the latest FTDI drivers.
The USB SX-Key can program the board just fine, but when I try to debug, it fails after the software is loaded. I get a communication error dialog and the debug window says the processor is in "Sleep" mode. If I try to run anyway, I get more commo error dialogs with small decimal numbers (<512).
These are my switches:
        device  SX48,OSCRC
        irc_cal IRC_SLOW
        freq    50_000_000
        id      'IND RFID'
        reset   reset_entry
Has anyone else encountered this problem and maybe know a workaround? It has not caused a crisis yet because I still have a serial Key. But eventually there will be issues.
Larry
  • Larry MartinLarry Martin Posts: 106
    edited 2008-09-08 16:56
    Corrections:
    The USB SX-Key is Rev A, not Rev 1
    The first error dialog is "SX-Key not found on COM4"
    The subsequent "Communication Failed" error dialogs pop up when I press "Reset". Run is grayed out.
    Tested with SX-52.
  • Guenther DaubachGuenther Daubach Posts: 1,321
    edited 2008-09-08 17:47
    Larry,
    you will need the latest SX-Key IDE version which is 3.2.92h BETA, available at www.parallax.com/Portals/0/Downloads/sw/sx/Setup-SX-Key-Editor-v3.2.92h-BETA.exe.zip. Former versions, like yours do not support the SX-Key USB.
    Greetings from Germany,
    G
  • bassmasterbassmaster Posts: 181
    edited 2008-09-09 00:48
    same problem with the latest 92beta, no resonator, greyed out dubugging buttons. I am RMA'ing it
    Post Edited (bassmaster) : 9/11/2008 12:00:53 AM GMT
    edited 2008-09-09 01:42
    3.2 came on the CD with my USB SX-Key
    I will try 92h tomorrow, though I see bassmaster has the same problem I do.
    Larry
    edited 2008-09-09 10:16
    Larry,
    the error message "SX-Key not found..." indicates that the IDE could not establish communication with the SX-Key USB. To "let the IDE know" which type of SX-Key is connected (serial or USB), the types send different answers to the IDE. Former versions of the IDE "don't know" about the SX-Key USB, so when they see the answer from an SX-Key USB, they simply assume that this did not come from an SX-Key, and report that they could not find one.
    The blue LED on the SX-Key USB indicates an active communication with the IDE when it is lit.
    G
    edited 2008-09-09 21:39
    Beta 92h is failing in a new way.
    Now, I no longer get the "SX-Key Not Found" message after the code is loaded for debug. However, the SX48 is not in a good state, either. The Debug window says "Running" and all the debug buttons except "Reset" are grayed out. It looks like a program with a breakpoint is running. Problem is, my program has no breakpoint, and it's not running. The version banner does not come out the programmed serial port, LEDs do not come on (=> output pins are tristated). The Reset button has no effect.
    I have verified that both 3.2 from CD and 3.2.92h Beta work well with my serial SX-Key, both with my design board and a 2005-vintage SX 48/52 Proto Board from Parallax (SX52 BD). The USB SX-Key fails as described on the Parallax Proto Board.
    A screen shot and Portmon log are at http://gluelogix.com/parallax/
    Post Edited (Larry Martin) : 9/9/2008 9:48:31 PM GMT
    edited 2008-09-09 22:57
    Thanks, I just submitted my RMA request.
    Larry
  • Capt. QuirkCapt. Quirk Posts: 872
    edited 2008-09-09 23:35
    This might be obvious, but I recently made the mistake of not removing the Resonator before programming with the key. Does the exact same thing, as your problem when you leave the resonator in place.
  • dkemppaidkemppai Posts: 315
    edited 2008-09-10 00:12
    Capt. Quirk said...
    FYI, Also, Brownout settings can do weird things if set to the wrong values...
    "A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
    edited 2008-09-10 01:12
    I had 2 other problems, that caused that:
    (1) The 4 pin connector on my SX key was dirty or had a poor connection.
    (2)·The Power·switch on my PDB will show the power is on, but it will only let the SX-Key or Blitz program an SX about 1 out of·6 tries (figure that one out).
    Cleaning the connector worked, but not with the switch.
    edited 2008-09-10 01:25
    yep I have seen it all, breadboard issues and wire length also can cause issues. my most memoriable was a propeller crystal wire was running too close to the eeprom move it a fraction of an inch and it worked. Another was a logic detector that I still leave on the origional breadboard because on this breadboard it lights up the data led when my hand gets 4 inches away!
    Sean
    edited 2008-09-10 02:31
    I think the fact that the serial SX-Key does everything perfectly, with all the board/software combinations I tested, says that the problem is not dirty pins, undisciplined resonators, or reflected EMI.
    Prompted by Bassmaster's link, I 'scoped my OSC pin. When the system is in its bad state, there is a 3.8 MHz square wave on that pin. It should be 50 MHz. And I tried changing the brownout setting from Off to 2.2V. No joy.
    The PC does seem to be communicating with the USB SX-Key - when I click Reset, the clock stops for around 50 mS, actually spiking to 12V for 1 mS. But it comes back to 3.8 MHz, and the Run buttons are all grayed out.
    I sent an RMA request to sales@parallax.com. We'll see what happens.
    It seems the consensus is that if I buy another/newer one everything "should" be ok. For $50, maybe I should do that and keep this one as an expensive SX-Blitz.
    edited 2008-09-13 17:32
    my replacement usb sxkey arrived today and debugs perfectly, thanks patrallax for getting this issue resolved quickly.
    Sean
  • Astro FizzixAstro Fizzix Posts: 1
    edited 2008-09-15 20:00
    Hey guys I'm new to the forums here, but I love Parallax products! I'm a big fan of the BS2. I am however, a novice in the field despite a two-year technical degree and some ten years of tinkering.
    Ok I've read all you guys had to say about the "No Debug" issue, and I'm having the exact same issue with the SX28. The IDE (or whatever) states that the chip is "Running" when it should be "Idle". It will change to "Sleeping" when I unplug power, and the blue light is On the whole time. I've tried all the above debugs, I've tried different chips and boards. I have no external osc's and no Breaks and no Brownouts and all that jazz.
    Reading all about it seems the only resolve is RMA.....Say it ain't so! Is there anything else I might be doing wrong? Are there any other fixes? And what IS the issue here? Any help is appreciated....it's time to take a break for now!
  • megazoicmegazoic Posts: 5
    edited 2008-09-17 20:10
    I am also having the Debug problem with the SX28. I am running SX-Key v3.2.92h BETA on Win XP sp2 with the USB SX-Key Blitz. I have little experience with microcontrollers but much experience with coding software.
    I have been able to run the Led28.src as directed by the quickstart in the SX-Key Development System Manual but cannot debug it without the Debug window remaining in "Sleeping" mode (greyed out buttons). When this happens, the blue led is lit on the USB SX-Key. I have also attempted to follow the first tutorial in Programming the SX Microcontroller with similar problems. Some times I get an "Chip connection failed" error others I am able to initiate the Debugger and after the first step the Debug window is placed in the "sleeping" mode. In either case there is no resonator or crystal in the resonator socket.
    Any suggestions would be much appreciated.
  • PJMontyPJMonty Posts: 983
    edited 2008-09-17 21:56
    megazoic,
    The SX-Blitz doesn't debug. It just programs and verifies. To debug, you need an SX-Key. In the Parallax store, the webpage for the SX-Blitz...
    www.parallax.com/Store/Microcontrollers/SXTools/tabid/139/CategoryID/16/List/0/SortField/0/Level/a/ProductID/368/Default.aspx
    ...says this about the SX-Blitz:
    Unlike the SX-Key however, it does not provide in-circuit source-level debugging capabilities.
    PeterM
    edited 2008-09-17 22:53
    Sorry about the misleading information in previous post Peter. I purchased the SX Tech Tool Kit and am using the USB SX-Key to program/debug according to the SX-Key Developement System Manual and the Programming the SX Microcontroller books. All the information on the previous post is accurate, I believe.
    Thanks for any help - next step suggestions.
    edited 2008-11-16 20:42
    megazoic, i think Parallax will need to exchange it for a fixed one. they had a batch of sxkeys that were bad, they fixed most of them but I think a few got out in tthe sx kits. Call them. the rma process is fairly quick and easy.
  • CalebjoCalebjo Posts: 15
    edited 2008-11-20 02:21
    I have had the same issue about the debug going straight to sleeping mode when i try to run it. for some reason on my cpu if i change the frequency from 50_000_000 to 20_000_000 the program debugs just fine. I dont know why this works but whenever i try to raise the frequency the debug stops working. Please try setting your frequncy to 20_000_000 and tell me if that works.
    edited 2008-11-20 18:11
    Thanks for the feedback, I had tried several computers, parallax tech support and even rma'd the sxkey but same problem with new key. I thought I'd wait to see if others with better know-how would encounter this problem.
    Your suggestion of setting the clock to 20_000_000 has worked for me as well.
    Let me know if I can help to find the source of the problem - but please understand that I am new to working on microcontrollers!
  • BeanBean Posts: 8,129
    edited 2008-11-20 19:12
    One issue I have with my USB SX-Key is that is seems to be alot more sensitive to the capacitance on the OSCx lines than the Serial version was.
    With the serial version I could plug an SX28 dip into a breadboard and run wires to a 4 pin header to connect the SX-Key. But that doesn't work with the USB version. I think it will program, but it won't debug.
    If I bend the OSCx leads out so they don't go into the breadboard and plug the Key directly into them (and add wire for GND into the Key). Then it works fine.
    Bean.
    "The welfare of the people in particular has always been the alibi of tyrants." ~ Camus
    www.iElectronicDesigns.com
    edited 2008-11-21 06:37
    I'm glad that the 20_000_000 worked for you! I am new to programming the SX in assembly language and i was wondering if anybody knew how to connect pins to ground (my input technique of simply writing !rb, #%11011101 doesn't seem to be working for me). must be a noob mistake but I am out of ideas so any help is appreciateed. [noparse]:)[/noparse]
    My debug seems to be having strange actions now! Mine just says running all of the time and then the only time it says it is sleeping is when i turn the power off and hit the reset button. This SX-3.2.9Beta thing has been giving me a lot of other problems with my programs too. Anyone else have issues?
