2.5V on demo board
quick question...
i need 2.5V for the ADXRS300 gyro for the precision reference pin. how can i do that? whenever i find voltage dividers, it always has them going from +V and through resistors into -V. Since there's no -V on the board, i'm not sure what i'm supposed to do. any thoughts?
Harley Shanko
i've also been messin with an ADXL330 triple access accelerometer and i haven't done anything about regulating the current going into this. it's been working but i don't know if it'll break. this sensor is supposed to run on 320 uA. the board outputs at about 0.5 A so i guess i'm way over.
The 200uA is the amount of current the gyro will draw from the reference voltage supply. With any voltage divider, the output voltage is only what you expect if the current drawn is a small fraction of the total current drawn by the voltage divider. You can use Ohm's Law to figure out the actual output voltage given any particular output current. With the ratio I suggested (5mA : 200uA or 25 : 1), the output voltage will be pretty close to 1/2 the input voltage.
Paul Baker
