NEOPHYTE WARNNG
As one might guess, I am new at this...can anyone give me some tips as to what BASIC code might be used to store data on a 24LC128 EEPROM from multiple input sources (i.e. 2125 Accelerometer, HB55 Compass, SHT11 Temperature and Humidity Sensor, etc.)
· I am using a BS2 Stamp to juggle the data now, but I can only do one sensor at a time, and if I try to combine them I usually get the "Out of Memory" error.
· For right now, though I will be happy getting each sensor to upload data into the 24LC128, and will go to an FPGA Stamp with more memory later.
Stormy
PS - IF, however, one knows how I CAN get multiple sensors to run at the same time and upload data to 24LC128, I wouldn't complain...
Download Nuts and Volts Column #115 including the sample code: www.parallax.com/Resources/NutsVoltsColumns/NutsVoltsVolume5/tabid/448/Default.aspx
The sample code includes an example for the 24LC256 which is a 32K byte EEPROM. The 24LC128 is a
similar 16K EEPROM that's treated the same way.
With a Stamp, you can't really do more than one thing at a time, so you can't handle multiple sensors and logging to an EEPROM at the same time. For that, you'd need a Propeller which can do all that easily.
Post Edited (Mike Green) : 9/7/2008 10:38:49 PM GMT
I have appended a quick program combo that sends data from a Compass to the EEPROM for any interested parties.
...thinking a new Propeller is in my future...but when I am through I hope it is MY robot on the moon sending back data and pics
Stormy
See appended program file...
Stormy
