How to read two 24bit "words" @77kHz serial
·I'm trying to read·two 24 bit Bin.·"word"s (its not a byte or a word) So I call it a "word"....The BS2$ isn't fast enough to read this "word". (IT runs @ 77 kHz),I can see the output from the device useing the Parallax OSC. just as plan as day.The device has a data out·pin and a CLK.out pin. I put the DATA out on CH1 and the CLK out on the EXT.Trigger of the OSC. this sync. the data bits to the display on the OSC. This makes a "textbook" example of the·DATA packets. I·took some screen shots from the OSC. But I'll be Durned if I can find were I saved it to.·I'll rerun the tests and add the Attch. to this post.......
___%WMc$____out___
Post Edited (dazed&confused) : 9/7/2008 10:44:14 PM GMT
___%WMc$____out___
Please add a subject to your thread.
