Need Info: Mfg a product with a BS2 in it. — Parallax Forums
matts_persicmatts_persic Posts: 3
edited 2008-09-18 05:51 in General Discussion
I have a BS2 application I want to mfg.·a prototype three and am looking for information/recommendations on who can mfg the PCB and encase the circuit and BS in epoxy (it needs to be weather-resistant) or other enclosure.
Thanks for any info,
Matts Persic
+1 801 652-2590 mobile
matts.persic@doppelmayrCTEC.com
  • InSilicoInSilico Posts: 52
    edited 2008-09-07 07:51
    I don't know anybody that will put your board in epoxy for you, but for me a better solution would just put a normal PCB with your BS2 application into a weather-resistant enclosure. That way, you can service the board if you need to, but still protected from the elements.
    You can probably·to go to a Home Depot or Lowes and get one of those outdoor boxes for lawn sprinkler controllers and somehow mount your PCB inside it. Just about all of them come with a duplex AC outlet and holes for wires to come out, as well as someplace to mount your board via screws and whatnot (meant for the lawn sprinkler controller, but there's no law against repurposing the box).
    Hope this helps!
    edited 2008-09-07 17:55
    Matt's_per sic·
    These are very nice cases· a little price e thought
    Insulin
    Get one of those outdoor boxes for lawn sprinkler controllers and somehow mount your PCB inside it. Just about all of them come with a duplex AC outlet and holes for wires to come out, as well as someplace to mount your board via screws and whatnot (meant for the lawn sprinkler controller,
    This is for the PS Series.
    If you want a clear font window you have to add a "T" at the end of the part #
    It also·a good··idea.gif·to order the back plate for which ever type of box you order
    To view the· price of the cases to right side of the page view pricing by the size of the case·
    I have use these boxes as well they are very nice and easy to use
    The Links are on the Photos
    PS Series.····· These nicely priced
    Model 14121-000 Enclosures···· This one cost more money but a nicer box
    ··Thanks for any·idea.gif·that you may have and all of your time finding them
    Sam
    Post Edited (sam_sam_sam) : 9/7/2008 6:40:46 PM GMT
  • computer guycomputer guy Posts: 1,113
    edited 2008-09-18 04:48
    Some more information would probably help.
    What country do you need the work to be done in?
    What size is the project?
    Is there any plugs or sockets?
    Do you want epoxy or case?
    What quantity are you expecting to make?
    etc.
    Building Blocks To The Propeller Chip A web site designed to help people who are new to the propeller chip.
    Guitar Hero controller using the prop (WIP) --> HERE
  • SRLMSRLM Posts: 5,045
    Looks like he is in Utah by Salt Lake City... (area code 801)
    For designing and testing a box would work, but I don't see why a well designed epoxy solution shouldn't be used for production. The BS2 is reliable enough so that it need not be replaced in a well designed circuit. To that end, most end users would probably prefer to replace the whole module. I like the size savings afforded by coating the whole thing in a protective layer. Of course, I could be totally off the mark here.
