Cannot download the code RoamingWithPING.bs2"
I have recently bought a Ping))) sensor with the mounting bracket from Parallax. I have tested the Ping))) sensor using the programs Ping))) Dar and TestPingDirection, provided from Parallax’s website. Everything worked fine. Then I run into a problem that I cannot download the code “RoamingWithPING.bs2”, and the error message: “ Hardware Communication Failure!· Check Serial Cable and Power”.
I have check for:
Jumper for Vdd (5 V)
Batteries (Qty =· 4)
All connections that include IR, LEDs, Vdd, Vss..etc
All Cables that included the Ping))) sensor
Reboot the computer…etc, and
Nothing worked, same error message.
I would greatly appreciate any HELP and ADVICE.
Thanks in advance.
I have check for:
Thanks in advance.
The only thing about the specific program is that it's relatively large, so downloading has to succeed for longer than with a short program.
I am using IBM LapTop, P4, CPU 1.8G, 256MB RAM, Window XP.
Same error message was displayed after replaced the batteries and cleaned up the comments (to short a program). You could be right about “it’s possible to have an intermittent of poor connection” (i.e. cracks solder joints).
Could you please tell me – What is the changes from Rev. C to Rev. D on the Board of Education? The only different that I seen was the ‘Text’!
2) Cleaning up the comments won't make any difference in the program size. The comments are stripped out during compilation.
3) I don't have any other suggestions. I know that program will download successfully. You can always e-mail or telephone Parallax support directly.
When looking over the schematic Rev. D of the Board of Education w/USB interface. I have found that the USB IC’s and some components (please see the attached page 2 schematic of USB power circuit) on the actual print circuit board (PCB) of Board of Education Rev. D were not the same as shown on the Rev. D schematic. Such as the USB IC: FT232BM (schematic) vs USB IC: FT232RQ (PCB). Could you please explain why? or am I download the wrong (schematic) one!?
Please HELP or any ADVICE.
http://www.parallax.com/Portals/0/Downloads/docs/prod/boards/BOE_USB_D_Schematic.pdf
Parallax Engineering
Thank you so much.
Please look at the link of the revision D shematic provided by Chris, especially at the Microcontroller chip (BS2-IC) pin 23 (Vss)!? Take care and Thanks.
If the Stamp were an integrated circuit chip rather than a hybrid module, it would be important to connect both pins to ground because the wiring on the chip itself doesn't have much current carrying capacity. For a hybrid module, the printed circuit board traces are capable of carrying more than enough current for the module.
