Burn In Test using a Relay and a Basic Stamp and using Hyper Terminal
If this in the wrong place then Please move it to the·Basic Stamp·Forum
I hope that some one out there find this use full
[noparse][[/noparse] Program Description ]
' This Basic Stamp can use Hyper Terminal to see the relay work
' You do not need the Basic Stamp DEBUG window to see the seconds and if
' the relay is ON or OFF
' I was having a problem with a project that used a Relay and a Basic Stamp
' so I wrote this routine
' To trouble shoot the problem
' Found out when using a 2N2222A and a relay that the coil is rated at 12
' volts @ 75 mil lamps that sometime
' the DEBUG screen would go to gobbled tee gook some time when the relay
·' would turn ON
' I have Pill Bottle of 2N222A that bought on Ebay for a real good price so I
' want to use them
' Now when I have used relays that are 30 mil lamps or LESS
' I do not have this problem but when I use a UNL2803 and use 3 Input and 3
' Output Pins tied together for relay that
' more than 30 mil lamps
' I had to use a Optic Sensor and the 2N2222A which work very well no·
' problem at all
' I used two power supply's also and one transformer
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 9/5/2008 11:23:10 PM GMT
·' would turn ON
' want to use them
' problem at all
··Thanks for any·
·that you may have and all of your time finding them·
Sam
Parallax Engineering
Thank You for moving it to the right place
··Thanks for any·
Sam
Here is the results from a test i did on this new board that is going to use with this set up
·SECONDS· 018··· Laps··· 02547··· ON This about 2 days running with no problems
·The Set Up
I use a Optic Sensor and the 2N2222A· with a relay· 12 volts @ 75 millamps·which work very well no·
' problem at all
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 9/16/2008 10:13:10 PM GMT
