Boe-Bot wheel treads keep falling off
has anyone come up with a way to keep the Boe-Bot wheel treads on the wheel
when bot does a pivot turn they allways come off
I have thought about using glue but then I will need to replace them sometime in the future and I am concerned about the glue damaging the plastic wheels
I do not know of a better wheel to replace them with, besides I use them with the encoders so I need the holes in them.
Very technical question EH!!!!!!
Post Edited (kevinb2050) : 9/4/2008 1:27:34 AM GMT
Parallax Engineering
Post Edited (MSDTech) : 9/5/2008 5:39:20 PM GMT
I have stopped pivoting a wheel while I turn to reduce this problem but the Boe-Bot wheel bands seem to roll themselves off. The grooved profile of the wheels should allow a tight fit for a plastic spray on mold.
I originally wanted to mount the wheels on a rotating platform, but since the spray is highly flamable, I decided I didn't want an electric motor operating in the spray booth. I also found the material will soften styrene plastic - my first set of holders softened and dropped the wheels while the spray was still wet and I had to clean off the first attempt. The final result wasn't pretty, but the surface produced has traction and seems tightly adheared to the wheel. The next area to test is the durability of the coating and how easy it will be to remove when a new coat is required.
http://www.lynxmotion.com/Product.aspx?productID=303&CategoryID=39
http://www.junun.org/MarkIII/Info.jsp?item=34
It appears that they are the same item, but·Junun has a better price. Thanks to "erco" for the Junun link.
Duffer
Post Edited (Duffer) : 9/12/2008 10:16:24 PM GMT
From the Junun part description: "Tire thickness of 3mm will increase the diameter of the Mark III wheels from 67mm (with rubber band tires) to 71mm."
Duffer
They fit perfectly, do not roll even when put thru sharp turns
Zac is has a Boe-Bot chassis which has been widened to allow for the extra battery packs he carries and extra boards (has 4 boards - BOE, Parallax servo controller,speakjet and a misc board for shift registers connectors etc.
He also has a robotic arm fitted on the front of the chassis plus his body head (servo mounted Ping Sensor) - so all in all with the extra weight the tires worked fine.
I have Parallax wheel encoders fitted so I have had to recalibrate movement as the tires increase the distance of 1 revolution by approx 15mm - I did have concerns prior to purchase as to if the tires would clear the encoders. - they do with ease
I got a spare set just in case of wear but being in Australia and living upside down we have less gravitational force on tires so I should not need to replace them for a long time.
But then Parallax did use the Kangaroo when they designed the Boe-Bot
two feet (wheels) and a tail (pivot ball) to support the body (chassis) balance
