PC Power supply
I have a Prop Proto Board I want run off of a power supply pulled from an old PC. This means that I have regulated 5V at 14 Amps and regulated 12V at 4 amps. The Proto Board wants 6 to 9 volts. I can add another regulator to go from 12V to 9V, but it would be nicer if I could just bypass the 5V regulator on the Proto Board.
So the question is, can I get away with bypassing the 5V regulator and connecting my regulated 5V supply directly to the Proto Board's 5V rail. Or will this cause me grief?
--Micah
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
