Help with this project
Hello all, I'm new to this forum and micro controllers but not electronics.
So I'm having trouble with the code for this project. It needs to spin a motor with a paddle wheel attached a certain number of times and then stop for a certain amount of time. The external components (motor ,paddle wheel switch) are working fine. Since the BS1 can't count, I'm using the FOR...NEXT instruction to set a number of loops for both paddle counting and interval timing. I am planning on using FOR...NEXT a large number of times for some of the intervals (~6 to 12 hours). Is there a better way in the BS1? Right now it seems like the BUTTON instruction is resetting the FOR...NEXT instruction for the motor control. Here's the program: Thanks!
SYMBOL btn = 0 ' FOR BUTTON
SYMBOL btnWrk = B4
SYMBOL reps = B2 ' FOR...NEXT loop counter
motor:
HIGH 0
FOR reps = 1 TO 3 ' repeat for 3 button pushes
BUTTON Btn, 7, 1, 255, btnWrk, 0, No_Press
DEBUG "button"
TOGGLE 1
NEXT
timer:
FOR reps = 1 TO 12 ' repeat with Reps = 1,2,3,etc
PAUSE 60000
NEXT
GOTO motor
No_Press:
GOTO motor
SYMBOL btnWrk = B4
motor:
HIGH 0
DEBUG "button"
TOGGLE 1
NEXT
timer:
PAUSE 60000
NEXT
GOTO motor
No_Press:
GOTO motor
Parallax Engineering
This is actually controlling the movement of parts into a machine.
I think I read the clue I previously missed. The BUTTON instruction cannot stop a loop, which is where my head was. So, any tips on how to have the stamp let a set number of paddles go by before stopping the motor and continuing on with the instructions?
So, it seems to be working. Maybe not the most elegant of programming but it does seem to work -a starting point. The only change I made was where the No_Press condition branches to:
SYMBOL btnWrk = B4
motor:
HIGH 0
switch:
DEBUG "button"
TOGGLE 1
NEXT
timer:
PAUSE 60000
NEXT
GOTO motor
No_Press:
GOTO switch
