Menu Template for LCD Display
Hi All,
I'm new to this forum and this is my small contribution to the forum !
Carl
Carl
' File...... menu1.bsp
' Version... 1.0
' Date...... August 2008
' Purpose... Menu Template for LCD 16x2 and BS2p serie
' Author.... Carl Gosselin
' E-mail.... carlgosselin@yahoo.com
' {$STAMP BS2px}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
Lcd PIN 0 ' LCD Enable Pin
btn_plus PIN 11 '
btn_minus PIN 12 '
btn_menu PIN 13 '
' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
i VAR Byte
menu1_value VAR Byte
menu2_value VAR Byte
menu3_value VAR Word
' -----[noparse][[/noparse] Default Values ]-------------------------------------------------------
menu1_value=15
menu2_value=140
menu3_value=300
' -----[noparse][[/noparse] LCD Initialization ]--------------------------------------------------
Init_Lcd:
PAUSE 1000
FOR i = 0 TO 2
LCDCMD Lcd, 48 ' Reset LCD (Send 3 times)
PAUSE 5 ' Delay Require By LCD Specs
NEXT
LCDCMD Lcd, 32 ' Set 4-bit Mode
LCDCMD Lcd, 40 ' Set 2-line Mode
LCDCMD Lcd, 12 ' Turn On Display With No Cursor
LCDCMD Lcd, 6 ' Set To Auto-Increment Cursor
LCDCMD Lcd, 1 ' Clear Display
' -----[noparse][[/noparse] Main Routine ]----------------------------------------------------
Main:
LCDOUT Lcd,128+1, [noparse][[/noparse]"Menu"]
LCDOUT Lcd,128+70, [noparse][[/noparse]"Examples"]
PAUSE 3000
DO
LCDOUT Lcd, 2, [noparse][[/noparse]"Main Page"]
PAUSE 5 ' Stops Display flickering
'# Your Code Here
IF btn_menu = 0 THEN ' Call the menus sub routine if the button is pressed
GOSUB menu
ENDIF
'# Your Code Here
LOOP
END
' -----[noparse][[/noparse] Sub Routines ]----------------------------------------------------
menu:
DO
GOSUB menu_one
GOSUB menu_two
GOSUB menu_three
LCDCMD Lcd, 1
RETURN
LOOP
RETURN
menu_one:
LCDOUT Lcd, 1, [noparse][[/noparse]"2.Menu One"]
PAUSE 200
DO
LCDOUT Lcd, 128+64,[noparse][[/noparse]"[noparse][[/noparse]-]"]
LCDOUT Lcd, 128+77,[noparse][[/noparse]"[noparse][[/noparse]+]"]
LCDOUT Lcd, 128+67,[noparse][[/noparse]" "]
LCDOUT Lcd, 128+69,[noparse][[/noparse]DEC menu1_value, " Sec"]
LCDCMD Lcd, 1
PAUSE 300
RETURN
ENDIF
IF btn_plus = 0 THEN
menu1_value=menu1_value+1
PAUSE 200
ELSEIF btn_minus = 0 THEN
menu1_value=menu1_value-1
PAUSE 200
ENDIF
IF menu1_value < 10 THEN menu1_value=10
IF menu1_value > 30 THEN menu1_value=30
LOOP
PAUSE 1000
LCDCMD Lcd, 1
RETURN
menu_two:
LCDOUT Lcd, 1, [noparse][[/noparse]"2.Menu Two"]
PAUSE 200
DO
LCDOUT Lcd, 128+70,[noparse][[/noparse]DEC menu2_value,"F"]
LCDCMD Lcd, 1
PAUSE 300
RETURN
ENDIF
menu2_value=menu2_value+5
PAUSE 200
menu2_value=menu2_value-5
PAUSE 200
ENDIF
IF menu2_value < 120 THEN menu2_value=120
IF menu2_value > 190 THEN menu2_value=190
LOOP
PAUSE 1000
LCDCMD Lcd, 1
RETURN
menu_three:
LCDOUT Lcd, 1, [noparse][[/noparse]"3.Menu Three"]
PAUSE 200
DO
LCDOUT Lcd, 128+70,[noparse][[/noparse]DEC menu3_value,"Hz"]
LCDCMD Lcd, 1
PAUSE 300
RETURN
ENDIF
menu3_value=menu3_value+50
PAUSE 200
ENDIF
menu3_value=menu3_value-50
PAUSE 200
ENDIF
IF menu3_value < 200 THEN menu3_value=200
IF menu3_value > 600 THEN menu3_value=600
LOOP
PAUSE 1000
LCDCMD Lcd, 1
RETURN
Welcome to Parallax Forum
Very nice·work
Thanks for sharing it········
··Thanks for any·
Sam
Any chance something like this could be done for the BS2?
Deus tantum me iudicabit
