problems with the BUTTON command
following is my code. when a whisker comes in contact with something it runs the segment 10-20 times. any idea what's causing this?
Post Edited (Deathwing61) : 9/3/2008 3:41:49 AM GMT
' {$STAMP BS2}
' {$PBASIC 2.5}
' My first Robot
' I shall call him... Jean-Luc
' Go forward untill you feel something
TOP: 'lable
HIGH 0 'left wheel forward
LOW 1
HIGH 2 'right wheel forward
LOW 3
LeftButton VAR Byte
LeftButton = 0
RightButton VAR Byte
RightButton = 0
BUTTON 4, 1, 255, 0, LeftButton, 1, LeftWhisker
BUTTON 5, 1, 255, 0, RightButton, 1, RightWhisker
GOTO TOP
LeftWhisker: 'If left whisker contacts do this
LOW 0 'left wheel reverse
HIGH 1
LOW 2 'right wheel reverse
HIGH 3
PAUSE 500 'reverse .5 seconds
LOW 0 'left wheel stop
LOW 1
HIGH 3
PAUSE 500 'back/turn right .5 seconds
GOTO TOP 'go back to program
RightWhisker: 'If Right whisker contacts do this
HIGH 1
HIGH 3
HIGH 1
LOW 2 'right wheel stop
LOW 3
PAUSE 500 'back/turn left .5 seconds
First let me say Welcome to the Parallax Forum
One Thing you need·do at very top of· your code is to define your PIN·VAR and CON at the top·
One thing to be care full of is where you put some commands it dose make a deferents·where you put them in your routines
TOP:······················'lable
··HIGH·0··················'left·wheel·forward
··LOW·1
··HIGH·2··················'right·wheel·forward
··LOW·3
··LeftButton·VAR·Byte
··LeftButton·=·0····· By putting this here you are forcing the LeftButton·not to rountine to be·running ·all the time
··RightButton·VAR·Byte
··RightButton·=·0··· By putting this here you are forcing the RightButton·not to· rountine to be·running·all··the time
··BUTTON·4,·1,·255,·0,·LeftButton,·1,·LeftWhisker
··BUTTON·5,·1,·255,·0,·RightButton,·1,·RightWhisker
This makes it a lot·easier to read and follow· something like this
' {$STAMP BS2}
' {$PBASIC 2.5}
' My first Robot
LeftWheel·········· PIN··········· 0
LeftWheelA········· PIN··········· 1
RightWheel········· PIN··········· 2
RightWheelA········ PIN··········· 3
LeftButton·········· VAR·········· Byte
RightButton········· VAR·········· Byte
Timer··············· CON·········· 500
·' By putting it here you only force it not to run·the·routine once
LeftButton = 0
RightButton = 0
TOP:······························· 'lable
·BUTTON 4, 1, 255, 0, LeftButton, 1, LeftWhisker
·BUTTON 5, 1, 255, 0, RightButton, 1, RightWhisker
· HIGH leftwheel·················· 'left wheel forward
· LOW leftwheelA
· HIGH rightwheel················· 'right wheel forward
· LOW rightwheelA
GOTO TOP
LeftWhisker:····················· 'If left whisker contacts do this
· LOW LeftWheel··················· 'left wheel reverse
· HIGH LeftWheelA
· LOW· RightWheel················· 'right wheel reverse
· HIGH RightWheelA
· PAUSE· Timer····················· 'reverse .5 seconds
· LOW LeftWheel··················· 'left wheel stop
· LOW LeftWheelA
· LOW RightWheel··················· 'right wheel reverse
· HIGH RightWheelA
· PAUSE· Timer······················ 'back/turn right .5 seconds
· GOTO TOP·························· 'go back to program
RightWhisker:························ 'If Right whisker contacts do this
· LOW LeftWheel······················ 'left wheel reverse
· HIGH LeftWheelA
· LOW· RightWheel···················· 'right wheel reverse
· HIGH RightWheelA
· PAUSE Timer························· 'reverse .5 seconds
· LOW LeftWheel······················· 'left wheel reverse
· HIGH LeftWheelA
· LOW RightWheel······················ 'right wheel stop
· LOW RightWheelA
· PAUSE Timer························· 'back/turn left .5 seconds
· GOTO TOP···························· 'go back to program
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 9/6/2008 3:49:59 AM GMT
Helicopter Pilot: "I'm lost where am I?"
Microsoft:"You're in a helicopter"
i'm using a quad half h-bridge ic
