Why won't this compile? cc = a ^ b — Parallax Forums
basicstampedebasicstampede Posts: 214
edited 2008-09-03 20:49 in General Discussion
Hello.·
I want to monitor two pins.
When the two pins are dissimilar, then I want to increase a counter by 1.
Here is my code.· It won't compile.· The error message says "unknown command LET".· What is this?
'·· File......
'·· Purpose...
'·· Author....
'·· E-mail....
'·· Started...
'·· Updated...
' Program Description
' Conditional Compilation Symbols
' Device Settings
DEVICE········· SX28, OSC4MHZ, TURBO, STACKX, OPTIONX, BOR42
FREQ··········· 4_000_000
' I/O Pins
Pin1 PIN RA.0 INPUT
Pin2 PIN RA.2 INPUT
' Constants
' Variables
·a VAR bit
·b VAR bit
·cc VAR bit
' INTERRUPT
'ISR_Start:
· ' ISR code here
'ISR_Exit:
· 'RETURNINT ' {cycles}································
· PROGRAM Start
' Subroutine / Function Declarations
' Program Code
Start:
· a = Pin1
· b = Pin2
· cc = a ^ b
· IF cc = 1 THEN
··· counter = counter + 1
· ENDIF
Main:
· GOTO Main
' Subroutine / Function Code
' User Data
  • BeanBean Posts: 8,129
    edited 2008-09-03 00:29
    XOR doesn't work with bit variables.
    Forget about cc altogether and just use "IF a <> b THEN".
    Bean
    "A government big enough to give you everything you want, is big enough to take away everything you·have."·· Thomas Jefferson
    "It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
    www.iElectronicDesigns.com
  • JonnyMacJonnyMac Posts: 9,809
    edited 2008-09-03 00:33
    Funny how the simplest solutions are usually the most elegant; that even matches the requirement statement: "When the two pins are dissimilar...."
  • basicstampedebasicstampede Posts: 214
    edited 2008-09-03 00:39
    Thanks Bean. That is good to know about XOR.
    edited 2008-09-03 00:54
    JohnnyMac, actually, my code was something like this:
    Main:
    SHOW_TIME
    oldpin = newpin
    newpin = TicPin
    'result = oldpin ^ newpin 'XOR does not work on Bit
    IF oldpin <> newpin THEN 'Forget about result, just compare oldpin v. newpin
    IF counter = 2 THEN
    counter = 0
    UPDATE_TIME
    ELSE
    I was actually monitoring 1 pin to see if it changed. So I saved it as oldpin, then got a new reading as newpin and tried to do an XOR.
    Anyway, now thinking again, I agree that I should have just directly compared it instead of XORing it.
    But I learned that XOR does not work on Bit variables.
    Thanks for all your help.
    edited 2008-09-03 01:02
    You will find new strategies moving from the BASIC Stamp to the SX; sometimes they seem like a lot more work, but what you really don't see is how much work the BASIC Stamp actually does for us, though you begin to get an idea once you start coding the SX.
    I'd still like to see your whole program or what you're attempting to convert; sometimes fragments have no context and one would approach them differently given a "big picture" view.
    [noparse][[/noparse]Edit] Looking at your code, I think this is more efficient and accomplishes the same thing:
    Main:
      SHOW_TIME
      IF TicPin <> oldPIN THEN
        oldPin = TicPin
        INC counter
        IF counter.0 = 1 THEN
          UPDATE_TIME
        ENDIF
      ENDIF
    ... basically it calls the UPDATE_TIME subroutine on every other change of TicPin.
    And, just for grins, here's another way to do it. Let's say you want to call UPDATE_TIME when you have a 0 to 1 transition on TicPin; here's a possible solution:
    Main:
      SHOW_TIME
      ticCheck = ticCheck << 1                      ' last check to BIT1
      ticCheck = ticCheck & %11                     ' clear all but bits 1 and 0
      ticCheck.0 = TicPin                           ' sample to BIT0
      IF tixCheck = %01 THEN                        ' if last low, new high
        UPDATE_TIME                                 '   update
      ENDIF
    This second segment of code uses just one byte versus one byte + one bit, or one byte + two bits with your original code.
    Post Edited (JonnyMac) : 9/3/2008 1:29:02 AM GMT
    edited 2008-09-03 18:20
    Jonny Mac, below, please see my entire code. Thanks for all your help.
    ' File...... Stampworks10
    ' Purpose... Stampworks 10 in SX/B
    ' Author.... C.M.
    ' E-mail....
    ' Started... Sept. 1, 2008
    ' Updated...
    ' 8 digit LED
    ' takes input square voltage in TicPin (RB.0) and uses this as timing signal
    ' displays time in four 8 segment LEDs
    ' uses time multiplexing and persistence of vision
    ' Device Settings
    DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX, BOR42
    FREQ 4_000_000
    ' I/O Pins
    Segs PIN RC OUTPUT
    TicPin PIN RB.0 INPUT
    DigSel PIN RA OUTPUT
    ' Constants
    Blank CON 0
    Dig0 CON %1111 'all digits off
    Dig1 CON %0111 'tens minutes digit
    Dig2 CON %1011 'ones minutes digit
    Dig3 CON %1101 'tens seconds digit
    Dig4 CON %1110 'ones seconds digit
    ' Variables
    'idx VAR Byte
    counter VAR Byte
    sec VAR Byte
    seconds VAR Byte
    minutes VAR Byte
    sec_ones VAR Byte
    sec_tens VAR Byte
    min_ones VAR Byte
    min_tens VAR Byte
    digit VAR Byte
    digitvalue VAR Byte
    value VAR Byte
    pinstatus VAR Byte
    time VAR Byte
    oldpin VAR Byte
    newpin VAR Byte
    result VAR Byte
    ' INTERRUPT
    'ISR_Start:
    ' ISR code here
    'ISR_Exit:
    PROGRAM Start
    SHOW_TIME SUB 0
    UPDATE_TIME SUB 0
    ' Program Code
    Start:
    counter = 0
    sec = 0
    digit = 0
    DigSel = Dig0
    newpin = TicPin
    Main:
    SHOW_TIME
    oldpin = newpin
    newpin = TicPin
    IF result <> 0 THEN
    IF counter = 2 THEN
    counter = 0
    UPDATE_TIME
    ELSE
    'only changed 1 time
    'oldpin = newpin ' try adding more code here
    ENDIF
    ELSE
    ENDIF
    WATCH sec
    WATCH seconds
    WATCH minutes
    WATCH sec_ones
    WATCH sec_tens
    WATCH min_ones
    WATCH min_tens
    WATCH value
    WATCH digitvalue
    WATCH oldpin
    WATCH newpin
    BREAK
    GOTO Main
    SUB SHOW_TIME
    'Segs = Blank ' try activating this
    digSel = Dig4
    READ DecDig+sec_ones, Segs
    PAUSE 1
    digSel = Dig3
    READ DecDig+sec_tens, Segs
    PAUSE 1
    digSel = Dig2
    READ DecDig+min_ones, Segs
    PAUSE 1
    digSel = Dig1
    READ DecDig+min_tens, Segs
    PAUSE 1
    DigSel = Dig0 'need this? try eliminating this.
    ENDSUB
    SUB UPDATE_TIME
    sec = sec + 1
    IF sec=60 THEN
    sec = 0
    sec_tens = 0
    sec_ones = 0
    min_ones = min_ones + 1
    IF min_ones = 10 THEN
    min_ones = 0
    min_tens = min_tens + 1
    IF min_tens = 9 THEN
    min_tens = 0
    ENDIF
    ENDIF
    ELSE
    sec_tens = sec / 10
    sec_ones = sec // 10
    ENDIF
    ENDSUB
    ' User Data
    DecDig:
    DATA %01111110 '0
    DATA %00110000 '1
    DATA %01101101 '2
    DATA %01111001 '3
    DATA %00110011 '4
    DATA %01011011 '5
    DATA %01011111 '6
    DATA %01110000 '7
    DATA %01111111 '8
    DATA %01111011 '9
    DATA %01110111 'A
    DATA %00011111 'b
    DATA %01001110 'C
    DATA %00111101 'd
    DATA %01001111 'E
    DATA %01000111 'F
    I wrote StampWorks, so I recognize that. Keep in mind, though, that what we're forced to do with BS2 we don't always have to do with the SX; in many cases direct translations simply cripple the capabilities of the SX.
    I've translated the program similar to what you're doing, but that program in StampWorks was to demonstrate the process of multiplexing, and was never intended to be a practical application. The SX has interrupts and that's the better way to go for this type of application. See the help file for a clock/time example using interrupts in SX/B. In the mean time you may learn a few tricks about SX/B from the attached program.
    For example: you should encapsulate high-level functions like PAUSE into a subroutine so that they just get compiled once -- this will save code space. You might want to go back and read all my Nuts & Volts articles that use the SX. Since I have to explain the project code it should be fairly educational, especially those articles over the last year or so. You can get them from the Parallax web site.
