PINK
Me and my friend are working on a project that requires use to communicate to the PINK ethernet module, and we're having problems. Whenever we try to sent a command (read variables), it will not go through. Any suggestions/help?
I'm the friend on this project. Honestly, we don't really have much together yet. We took the spin stamp, hooked up the pink ethernet according to the included documentation onto pins 10 and 11 (rx and tx respectively), and used 1K in series resistors. I tried using FullDuplexSerial and the simplest method of communication possible, basically pink.str(string("!NB0R00")) followed by LCD.print(pink.rx) in order to view the variable value. It didn't quite work, we tried various methods of doing it, and then our boss came by and pushed us back on the original project so we had to lay it aside. Frustrated, we are seeking out help here to find out how someone else has operated the pink.
~Some men see things as they are and ask "why?"
I dream of things that never were and ask "why not?"~
What does "didn't quite work" mean? What worked? What didn't work? Can you configure the PINK with a web browser?
http://obex.parallax.com/objects/category/5/?page=4
I have used the Pink with the Spin Stamp.
regards peter
The PinkV2 object is a direct conversion from my Javelin PinkV2 class.
Mike,
Thanks for posting that link. That particular project uses
the PinkV2 object in a real application.
regards peter
