Little Project: Long Rang PIR Sensor
This is weird.· Attached are my schematic and code.
This is what happens.· It works good for a while.· Then out of no where the propeller stops working or so I thought.· I found when the PIR sensor goes high, the propeller comes on.· I can program it but when the PIR sensor goes off the propeller goes off.· The·PIR sensor connects to pin 10 only!· The PIR sensor stays high for 2 seconds.
·- Ouch, thats not suppose to be hot!··
Michael King
Application Engineer
R&D
Digital Technology Group
PIR UDA Sensor.spin, v1.1,Michael King
│ Copyright (c) 2008 Michael S. King │
│ See end of file for terms of use. │
CON
CON
_clkmode = rcslow
'_xinfreq = 5_000_000
OBJ
Send : "FullDuplexSerial"
PUB main
clkset(%00000001 , 0) ' Set internal oscillator to RCFast and set PLL to start
waitcnt(cnt+120_000)
Dira[noparse][[/noparse]10]:=0 ' Set internal oscillator to RCFast and set PLL to start
Dira[noparse][[/noparse]15]:=1
repeat
waitpeq(%010000000000, %010000000000, 0) 'Wait port Port 10 to go high
clkset( %01101000,80_000_000 ) 'Set to XTAL1
waitcnt(220000+cnt)
clkset( %01101111,80_000_000 ) 'Set to XTAL1 + PLL16x
waitcnt(1000000+cnt)
outa[noparse][[/noparse]15]:=1 'turn on Xmitter
send.start(16,17,0,9600) ' start FullDuplexSerial
waitcnt(20_000_000+cnt) 'Wait a bit for the XTEND to be ready
send.str(string("<*00000001*S*>")) 'Send activation of sensor Message
waitcnt(20_000_000+cnt) ' Wait for message to be sent
send.stop 'Close down FullDuplexSerial
outa[noparse][[/noparse]15]:=0 'Turn off Xmitter
outa[noparse][[/noparse]17]:=0 'Ground 17 to prevent leakage.
waitcnt(cnt+500_000)
clkset(%00000001 , 0) ' Set internal oscillator to RCslow
waitcnt(cnt+80_000)
Michael King
R&D
Michael King
R&D
1. The outa[noparse][[/noparse]17] := 0 I dont believe will do what you are expecting, you dont set the pin to be an output in the cog anywhere. The serial port code sets output in its own cog which makes no difference to the main cog
2. The last 2 waitcnt should have cnt last.
I dont believe either of these is causing your problem though. So I would separate the functions as try to isolate the problem. Remove the output code and the clock changing code and just have the pir input code in a loop that does nothing. If that still has a problem its definitely the pir. If not try thr clock chaning stuff in a loop by itself. Try the xmitter on/off in a loop (with delays) by itself. i.e. try each piece until you understand which piece causes the problem. It all are ok, combine each in pairs, etc.
