MiniProp - alternative to Proto Board
Where I work, we often use the Propeller in tight spaces where the Protoboard won't fit.· I designed a smaller general-purpose PCB to solve the problem.· It is a very minimal design with prototyping area and one 3.3V regulator.· I thought I'd share the design with the group in case someone else might find it useful.· It's designed using ExpressPCB, so you have to order from them because it's a proprietary format.· If you use their Miniboard service, you can get 6 of these (3 boards, 2 per board)·for about $60, which makes them $10 each.· You'll have to do your own soldering...
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
- Bjarne Stroustrup
Cheers,
Simon
www.norfolkhelicopterclub.com
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again
BTW: I type as I'm thinking, so please don't take any offence at my writing style
Is the component list with the Express PCB schematic?
Never mind! I found them.
Do you have a picture·of your board populated?
Whit+
Post Edited (Whit) : 9/2/2008 6:47:44 PM GMT
Thanks for sharing.
I notice you're using .15mm traces - is there any problems running that thin? Do you have a working build of the board? I've typically stuck to .38mm or so
thanks,
James
- Bjarne Stroustrup
James
- Bjarne Stroustrup
- Bjarne Stroustrup
Very nice.
I got one of Bean's mini's... which draws power from my laptop, which makes it possible for me to work in my car, while I'm waiting for bowling to get over, etc. etc. He originally had a smaller version, and I wish I had gotten one. His current version has a very nice bread board area, so in terms of trying out ideas, it couldn't be nicer... and it has video out!!! But it doesn't have a prototyping area. So, when it comes time to making a one off prototype, I'm left wanting for something like this.
I'm finally beginning to enjoy soldering... but I don't think I could do this yet. I've looked at some of the instructional on this type of soldering and it looks really doable, but I think I'm going to wait until one of you guys comes out with one of those easy bake ovens.
What the world needs is a Prop on a board... just like yours... and nothing else.
At OBC's meeting he was showing his cut down proto board... actually pretty spiffy, but it looked terrible... all cut apart with a hack saw.
One suggestion, put some random traces between the holes. It would be fun to work with and if you didn't want a particular trace, you could always cut it.
Rich
- Bjarne Stroustrup
JMH - Electronics: Engineer - Programming: Professional
- Bjarne Stroustrup
Did you cut the heatsink off of the voltage regulator?
Whit+
I formed somewhat of a heat sink by putting a few vias to a large pad on the bottom of the board.· If you need more heat sinking capability, you can enlarge the vias and fill them with solder.
- Bjarne Stroustrup
Post Edited (Ken Peterson) : 9/3/2008 6:31:01 PM GMT
- Bjarne Stroustrup
I had thought about what it would take to do something similar with the 40 pin DIP (because I am OK at best with soldering), and maybe try batchpcb.com' service (that of course after I figure out how to use Eagle).
Post Edited (trodoss) : 9/18/2008 9:38:27 PM GMT
It is posible to to get only PCBs from You.
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer
If you don't ask you wont know
If your gonna construct something, make it·as simple as·possible yet as versatile as posible
Sapieha
In order to make it cost effective to sell them, I'd have to re-design it with an industry standard format and then have them made in much larger quantities. This is not something I have the time or inclination to do right now. But thanks for asking.
- Bjarne Stroustrup
