SD card breakout boards, Sparkfun, uController, sdspi .... pInsanity
Greetings SD card collectors,
I just got an SD breakout board from Sparkfun and have been trying to determine exactly how to hook it up. Lately I've been sifting through a lot of material on SD cards mentioned by the forum and I'm a little confused over what pins to hook up to what and why. There seems to be some disagreement among sources. Generally speaking, I think I know what Sparkfun's labels mean and to what pins on the Propeller they might be attached for the following: DO, CLK, DI, CS, GND, and VCC. My confusion centers over what to do with the remaining pins on the Sparkfun board; namely: IRQ, P9, CD, WP, and COM.
Observations made of other sources:
The "ready made" SD board from uController shows only pins P0 through P3 and VDD and VSS connected to something. Pins for IRQ, P9, etc don't seem to be connected to anything.
The sdspi object from the Object Exchange shows pins P9 and IRQ being connected to 3.3volts through a 20K resistor.
The Hydra SD Max Card I bought came with a schematic, but I suppose the labels for that schematic are specific to Hydra and are not labeled for general useage, and, besides, the schematic does not indicate where are the physical holes on the printed circuit board, so I have no idea what to solder to.
And I don't know what OBC's "The Propeller Cookbook" is trying to say about pins 8 and 9 - it seems that something was left out on his illustration.
I'm guessing that different folks have different strokes on what to do with these "left over" pins. I'd be interested in hearing everyone's opinion on what works so I don't fry my hard-earned data down the road.
a thousand thanks,
Mark
a thousand thanks,
Mark
i just have the DO, CLK, DI, CS, GND, and VCC hooked up on mine, and it works ok.
i assume you could hook up the write protect pin if you needed that function, not sure about cd.
dan
WP is "write protect" protects the card from being written over or erased. There's no provision for it in software, so really not needed in a Propeller application
CD is "Card Detect" - once again, the software doesn't have a provision to sense if a card is inserted. It checks by software if a card is detected. I use CD on the uController boards to turn on an LED when a card is inserted.
to see the connections I use, and what gets pulled high -
ucontroller.com/documentation/SDCardDoc.html
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Post Edited (parts-man73) : 9/2/2008 1:21:20 PM GMT
He is just showing the minimum·what you need to make it work.
I have Brian's SD Card Adapter. I like the the indicator light.
Whit+
Post Edited (Whit) : 9/2/2008 2:11:34 PM GMT
I've built several to that specification without issue now. Don't sweat the extra connections. [noparse]:)[/noparse]
(BTW, I'm working on an expanded version of the Cookbook for print publication.)
The Sparkfun adapters, while they worked for me were someone confusing compared to
the others (uController, or designing your own from a socket).
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
thanks for jumping in on my question and providing me with some answers so early in the day. Now I can actually get started on my SD Card adventure with some reasonable confidence.
you guys are great!
thanks as always,
Mark
