What is wrong with viniculum hexa short mode?
Hi all,
I develop an application nowadays using the datalogger of Parallax.
I meet problems during the writing of a file in hexa short mode.
The problems seems to come from order writing.
I followed directives of the datasheet but order does not have effect.
I then tried the mode long ascii which it, works.
Firmware version was 3.61 that I changed in 3.65 but problem persists.
Is what somebody a met this problem? Is there error datasheet?
I tried all this strings as command. But all gone wrong.
And this one work fine.
There no issues with others command strings like :
con WRF = 8
dat StrCmd1 byte WRF, $20, $05, $0D, "hello", $0D StrCmd2 byte WRF, $20, $05, $0D, "hello" StrCmd3 byte WRF, $20, $00, $00, $00, $05, $0D, "hello", $0D StrCmd4 byte WRF, $20, $00, $00, $00, $05, $0D, "hello"
dat StrCmd1 byte "WRF 5", 13, "hello"
dat InitStr byte "SCS",13 DirFileStr byte DIR, $0D OpenWFileStr byte OPW, $20, "myfile.ini", $0D CloseFileStr byte CLF, $20, "myfile.ini", $0D
