Com setting SX-key — Parallax Forums
Com setting SX-key
datacpsdatacps Posts: 139
edited 2008-09-01 15:40 in General Discussion
······ I was trying another program on the same USB port where I program my SX with. After trying to com with this program and my new hardware, I changed the configuration trying to com with it then stopped and went back to program my SX and now I only have Com 1 and Com 2 in the config menu. It was all working perfectly before. Do I have to reinstall the SXKey and set it up on the initial setup.
When I go into the config I only get 2 options. What happened? Where did I go wrong.... I·don't know what I did wrong but it looks like I lost the other options for the·com·ports..· SX-key v3.2.3··Thanks
  • JonnyMacJonnyMac Posts: 9,809
    edited 2008-08-31 16:24
    The SX-Key IDE scans for available com ports when it starts. If you USB device is not plugged in when the IDE starts, it won't be listed.
  • datacpsdatacps Posts: 139
    edited 2008-08-31 19:21
    Thanks Jon You are correct It's working again and now it also show Com port 7 where the SX is on......... Also just wanted to let you know the only reason I bought a sub to Nut's and Volts is for your articles, I hope you get kickbacks or something...from it,, LOL ...
    Thanks again..
  • Shawn LoweShawn Lowe Posts: 635
    Yeah, I agree, Jon's articles make program the SX seem SOOOO easy. Until I try then, hhhmmm appearantly my brain jumps out a window. [noparse];)[/noparse]
    Shawn Lowe
    When all else fails.....procrastinate!
