Question About PINK
Hi folks,
I used the Parallax products 10 years ago in many designs and am just now getting back into using the products and have a question about the PINK.
I've had the PINK for about a week now - very easy to use and great fun!
On the nb_config.htm screen you can set "Web access Password Settings" with a Web file user name, Web file password and Web file password filter. I've found that if you specify a user name and password and leave the password filter blank, meaning you want all WEB files served to require a password, that you can not communicate using the serial interface [noparse][[/noparse]Stamp to PINK] - this includes sending email, reading / writing variables and running·the telnet debug session.
If I specify a password filter, then all works fine.
Is this normal - That the Web access password configuration settings affect the serial interface?
Thanks.
Thanks.
This is not normal operation and something I will test for Tuesday. Have you tried powering the module off and back on between changing these settings to make sure there isn’t something else going on?
Parallax Engineering
I removed the password filter again, then powered down and up and that did resolve the issue. All working fine now.
Donnie
I've been thinking about buying PINK, but hesitated because I am not sure HOW I should connect it.
That is, can someone give me a simple, "30,000 feet overview" of·how to connect it?··Something like:
····Internet··<-->· PC·<--> PINK·<--> BS2
······································ Internet via (XYZ connector)
- Stephen
For the Ethernet connection, would that be·the Ethernet connection at·back of my AT&T DSL wireless modem?
You can then use one·of the free services·offered on the NET·to keep track of·your WAN·IP so that you can access·PINK with a node name, not your DSL IP, as·the IP·can change daily. no-ip.com is one.
Donnie
The components I'm using on the board are the Emic, SSI202 for touch tone decoding, [noparse][[/noparse]using the Stamp for touch tone encoding], XECOM XE0052SIP for connection to telephone·line·[noparse][[/noparse]moving to·cell module later], PIR, VF display and Sensirion SHT11.
I'll use X-10 as well. I'm currently using the BS2, but switching to BS2p-40 for the additional I/O and features.
For the WEB page development·I'm using MS FrontPage, then dragging and dropping them on an open PINK ftp session window.
Donnie
