USB or Serial
Just a quick Question,
I have built a machine that transplants plants from one type of tray to another. In order to change trays I have to reprogram two BS2 controllers. This I have done from My Laptop for several years. Sadly this laptop has died from lack of care etc. As most new laptops dont have serial ports, do i need to find an old one that does or can I use the usb port in some way.
The one on the Parallax store is highly recommended as it supports all the signals necessary for Stamp programming.
Alternatively, get a surplus laptop from e-bay or a local office equipment firm. I still have a couple of Win95 machines on the go to support some older projects.
Cheers,
Tom Sisk
http://www.siskconsult.com
Be sure to load the FTDI drivers before you plug in the cable.
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/List/1/catpageindex/2/ProductID/378/Default.aspx?txtSearch=serial+to+usb&SortField=ProductName%2cProductName
The new drivers can be downloaded on the same page. This is are really handy and work great for the transition you are facing. Be sure to get a USB A to mini B cable (#805-00006) (or the spiffy USB A to Mini B Retractable Cable, which is a little cheaper) if you don't have one already!
Whit+
Post Edited (Whit) : 8/31/2008 5:01:49 PM GMT
