Relay Switch
Hello,
I need to switch on and off a standard 110 volt light bulb. I know this can be done with a relay switch. I will be using a BS2 to control the relay. Can anyone recommend a relay switch that works with the BS2? A name and model and or link to one would be great.
JB
JB
You should read this article .. contains all you need including part no.'s
www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol7/col/NV130.pdf
John
'Necessity is the mother of invention'
Those who can, do.Those who can’t, teach.
Look at this: http://www.radioshack.com/search/index.jsp?kwCatId=&kw=relays&origkw=relays&sr=1
PO2L
and some 330 ohm resistors. Simple diagram attached.
My opinion is to use an SSR in such scenarios ...for a number of reasons -galvanic isolation,Zero Cross over,low switching current - no need for extra components.No need for protection diode (to protect against back emf generated by inductive load switching) and it is solid state (no moving parts) .
John Twomey
