Calc theta, x, y from diff. drive encoders -- what am I doing wrong?
Hey all -- I'm reading encoder info into a BS2p40. I'm pretty sure I've got my math right, but I'm getting garbage (values all over the place) on my theta.
The encoders are delivering accurate ticks info. See relevant code for comments. In the case of figuring theta (rads to brads) I'm working fixed point (256.256). If I get this working right, I may use some of Tracy Allen's long division/mult. to get better resolution, but as it stands, where I might expect to get 0 change in theta sometimes because of the resolution, I get swings all over the place. The raw dist (distL + distR/2) and in a straight line it's pretty much dead nuts on. The posx and posy are off because the theta jumps all over.
Note that the encoder deliver the signed word *change* since the host last requested a sample; the actual range is about -40 to 40 each sample MAX, with average being around -15 to 15).
Any suggestions, comments, mistakes pointed out, are welcome.
Post Edited (Zoot) : 9/7/2008 2:26:10 PM GMT
ioWord VAR Word buffer0 VAR Word buff0 VAR buffer0.LOWBYTE buff1 VAR buffer0.HIGHBYTE buffer1 VAR Word buff2 VAR buffer1.LOWBYTE buff3 VAR buffer1.HIGHBYTE buffer2 VAR Word buff4 VAR buffer2.LOWBYTE buff5 VAR buffer2.HIGHBYTE buffer3 VAR Word buff6 VAR buffer3.LOWBYTE buff7 VAR buffer3.HIGHBYTE buffer4 VAR Word buff8 VAR buffer4.LOWBYTE buff9 VAR buffer4.HIGHBYTE motos VAR Word motoL VAR motos.LOWBYTE motoR VAR motos.HIGHBYTE moto VAR motoL accL VAR Byte accR VAR Byte ioByte VAR Byte SPaddr VAR Byte i VAR Nib sign VAR Bit sign2 VAR Bit WHEEL_BASE_CM CON 296' in 10th cms 'WHEEL_BASE CON WHEEL_BASE_CM * CMtoTicks_HM >> 16 + 1 WHEEL_BASE CON 114 ' in ticks 113.664 WHEEL_BASE_HALF CON WHEEL_BASE + 1 >> 1 ' FOR ROUNDing 'WHEEL_BASE_HM CON $10000 + WHEEL_BASE_HALF / WHEEL_BASE '431.651315789474 ' 1 / wheel_base * $10000 = 576.576576576577 with ** WHEEL_BASE_HM CON 576' for using ** instead of / WHEEL_BASE 'convert to brads 40.7436654315252 '128/PI 256/TWOPI '6.283185307 RadsToBrads_M CON 41 ' 256/2PI = with * RadsToBrads_HM CON 48737 ' 256/2PI = 4.7436654315252 * $10000 = 48,736.8577204355 with ** + hi RadsToBrads_Hi CON 04 ' equiv to -- 256/2PI -- x ** .74 + ( x * 4 ) RadsToBrads_Hi256 CON RadsToBrads_Hi * 256 ' but we're working fixed decimal place in 256ths ' / base * toBrads = 0.358457079035800253378378378378 * $10000 with ** 23491.843131690205405405405405381 DivWBtoBrads_HM CON 23492 '-------------------------------------- 'preloads signed encoder ticks change since last sample 'buffer0 -- signed Word -- L ticks change since last reading 'buffer1 -- signed Word -- R ticks change since last reading GOSUB Get_Odometry ' dist = (left_dist + right_dist) / 2.0; buffer2 = buffer0 + buffer1 ' add change since last reading sign = buffer2.BIT15 ' save sign buffer2 = ABS buffer2 + 1 >> 1 ' /2 with rounding buffer2 = -sign ^ buffer2 + sign ' restore sign ' theta += (r_dist - l_dist) / WHEEL_BASE; buffer3 = buffer1 - buffer0 ' note that distances AND wheel base are in units of "ticks" sign = buffer3.BIT15 ' save sign buffer3 = ABS buffer3 << 8 ' work in 256ths, i.e., fixed decimal point number from -127.255 to 127.255 buffer3 = buffer3 ** DivWBtoBrads_HM ' equiv to below two statements, in one single high-multiply ... 'above equivalent to: ' ( ( r_dist - l_dist ) / wheelbase ) * ( 256/TWOPI ) 'buffer3 = buffer3 ** WHEEL_BASE_HM ' / wheel_base 'buffer3 = buffer3 ** RadsToBrads_HM + ( buffer3 * RadsToBrads_Hi256 ) 'convert rads to brads * 40.7436654315252 or 128/PI 256/TWOPI (6.283185307) buffer3 = -sign ^ buffer3 + sign ' restore sign -- signed theta change in brads, fixed decimal point GET theta, Word ioWord ' add to running theta (256ths) ioWord = ioWord + buffer3 PUT theta_LSB, ioWord.BYTE0 PUT theta_MSB, ioWord.BYTE1 ioByte = ioWord + 128 >> 8 ' round to whole brads for sine and cosine ops ' X_pos += inches * COS(theta); ' Y_pos += inches * SIN(theta); sign = buffer2.BIT15 ' buffer2 is distance traveled since last sample from first steps buffer2 = ABS buffer2 buffer0 = COS ioByte ' x pos sign2 = sign ^ buffer0.BIT15 ' save sign, XOR with dist sign buffer0 = ABS buffer0 */ 516 ' normalize -- sin/127 = x/256 for use with */ buffer0 = buffer2 * buffer0 MAX $FF7F + 128 >> 8 ' equiv to */ with rounding buffer0 = -sign2 ^ buffer0 + sign2 ' restore sign buffer1 = SIN ioByte ' y pos cos sign2 = sign ^ buffer1.BIT15 ' save sign, XOR with dist sign buffer1 = ABS buffer1 << 1 ' * 2 = normalize -- sin/128 = x/256 for use with */ buffer1 = buffer2 * buffer1 + 128 >> 8 ' equiv to */ with rounding buffer1 = -sign2 ^ buffer1 + sign2 ' restore sign GET posx, Word ioWord ' add to running x position ioWord = ioWord + buffer0 PUT posx_LSB, ioWord.BYTE0 PUT posx_MSB, ioWord.BYTE1 GET posy, Word ioWord ' add to running y position ioWord = ioWord + buffer1 PUT posy_LSB, ioWord.BYTE0 PUT posy_MSB, ioWord.BYTE1 '--------------------------------------
Do you DEBUG "buffer3" in the steps it takes from the raw data to theta? That I think would help to reveal where it is blowing up. I don't see offhand.
How many ticks per revolution of the wheel?
Tracy Allen
www.emesystems.com
I am going to setup a step by step debug sometime over the weekend so I could watch each step in the calculations, but probably won't get to that till tomorrow night (trying to take a real weekend off!).
I get perfect data in (signed word representing change in ticks since last reading) and have tested that side of things extensively w/o error.
http://www.seattlerobotics.org/encoder/200010/dead_reckoning_article.html
http://www.seattlerobotics.org/encoder/200108/using_a_pid.html
I am running continuous servos controlled by a PSC (servo controller) and trying to get my head around Phil Philgrims article "Applying the Boe-Bot Encoders"
Questions
1. are you using continuous rotating servos
2. If so are you pulsing them or are they running on a PSC (servo controller)
2. no
I've got homebrew optical encoder discs on the main wheels themselves (144 ticks per revolution or about .26cm per tick). Homebrew electronics (Hammatsu emitter/detectors) hooked up to a "slave" SX. The SX drives 8 servos with ramps, handles encoder, velocity and odometry tasks, and sends output motor speeds to an MD22 motor controller (via I2C). A Stamp is the main host for the 'bot, running several peripherals, sensors, etc.
Phil's writeup is really good -- but keep in mind that rather than pure velocity control (independent of odometry) he took a really elegant approach of pulse management to keep the Boe-bot moving straight and turning accurately. Also his method of figuring a vector heading based on actual angular tick resolution is really cool.
I'm not going for that kind of precision -- I mostly need the velocity control and the odometry is a bonus. I don't neeed 1000s of meters of dead-reckoning, just a "good enough" idea of orientation (e.g. if the 'bot needs to turn 180 degrees, it will do so with a reasonable realiablity). I used the straight-up trig version of calculating theta (in radians) and x/y.
Here' a link to some of the hardware: http://forums.parallax.com/showthread.php?p=719074
However I expect now that with the encoders I need to monitor the clicks all the time and will not be able to go do other things in the program.
I played last night using debug to see how the encoders reacted and found that if I was away from the clicks to long I missed the count
The beauty of PhiPi's writeup is that he uses the time *in-between* servo pulses to do everything else. Keep in mind that the Boe-bot is very slow (relatively) and with only 16 ticks per wheel this becomes doable.
You can use counter ICs, program an SX, use another Stamp, PWMPal has counters that would work also.
Post Edited (kevinb2050) : 9/5/2008 3:49:50 AM GMT
Got the encoders working - connected direct to BS2e (no counting IC)
1- send command to the PSC to run servos until encoder count x
2- get sample from encoders
3- when reached preset count x send command to PSC to stop/change direction of servos
I have a delay in the code of Pause 20 and have not experienced any miss count
when I increase the pause to 40 I begin to miss encoder pulses
I expect that with continuous motion that I will only have a window of 20us to apply any calculation
if I don't use counting ICs. This should be enough as Phil's paper indicated as I only need to look for
any inputs from ir and ping sensors in this period.
So Far So Good - now to work out the calcs - God I hate Trig
