Help-not sure about holes on propeller proto board
I'm new at working with boards. My question is related to the innermost "holes" (for lack of a better term) on the Parallax Proto board. The holes marked P0-P31 are I/O ports, right? And VDD holes supply 3.3 volts? What about the ring of holes just next to those? Are they I/O ports or power? Also, where would you attach simple things that just need power and not I/O, such as LEDs or a piezo speaker?
Thanks!
Thanks!
If you look closely at the TWO rows of holes/pads around the Prop area, you'll note each pair away from the Prop are connected on the top side; use a multimeter to verify this if needed.
The rest of the other holes away from the Prop are unused; for use for what ever purpose needed. A very useful breadboarding area for us Protoboard owners.
Harley Shanko
I don't want to appear dim, or anything, but what does this mean?·Do both·holes/pads do the samething? -i.e., the·P0 pad and its neighbor hole...are they BOTH I/O port 0?
Both holes under VDD...are they both·3.3 volts?·
You can place LEDs on the protoboard, just make sure you use a current limiting resistor and you shouldn't damage anything.
I would suggest probing around the protoboard with a DMM on continuity to see which pads are "touching" each other and ofcourse read the protoboard documentation.
Rick
What do you have in mind?
Take a gander at the two guides below, they will give you more
ideas for those little holes. [noparse]:)[/noparse] Welcome to the Propeller.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
