UAV Science fair project using the BS2p24 or 40
Hello,
One of my friends and i are working on a science Unmanned Aerial Vehicle controlled with a BS2p hopefully the 40 pin model, but possibly the 24. Now i realize i would be better off with a propeller chip or something along those lines, but we are fairly sure we can get this to work. My question though is does anyone know where i can buy a BS2p24/40 Demo Board for under $100 and then have it shipped into Canada fairly cheaply? The one place i was able to find it in stock would cost me $65 to ship it, and there are very few places that ship it anymore. Also can anyone recommend and other development boards that are cheaper and will work with the BS2p40 other then the professional development board?
Thanks, I will be continue to post our progress as we move along with our project (I still have to get around to posting my finished "Jeeves" project bot).
- Stephen
A UAV can be put together with just a BS2p24 and a GPS.
Checkout the attached·code files.
Start with uav.bsp and work your way through the rest of the code files.
Each code segment is designed to fit in the BS2p's 2k eprom banks.
I did not write the code, but got it from a UAV website. I have modified the code to work with a UTV.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
Post Edited (Tom C) : 8/30/2008 10:54:28 PM GMT
Cheers,
Simon
www.norfolkhelicopterclub.com
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again
BTW: I type as I'm thinking, so please don't take any offence at my writing style
- Stephen
Thanks for all the help everyone, any further help or suggestions/ comments is really appreciated too.
As for the accelerometer, you only need one (in the main body most likely since the bot will know what position the servos are in that control the arm. And might I ask: what is the acceleromter supposed to do? If you want it to sense when the bot is tilting over it won't work. It will confuse a change in speed with tilt, and correct with catostrophic effects. To sense tilt, you need a gyroscope.
The BS2p code files that I attached to my reply were the original "UAVParallax" code files while the code files that include rcmode.bsp came later and are called the "BasicStampUAV" code files.
TCIII
4 AAA batteries, rechargeable, would be a good pack. Or, you could get
a 7.2 volt rechargeable pack, that would work well too.
For a small platform, you want a battery source that you will completely
drain in 15 to 30 minutes. Any more would simply be weight you carry
around to no purpose.
