Easy way to count the number of 1's in a long? — Parallax Forums
RaymanRayman Posts: 16,383
edited 2008-08-30 16:45 in Propeller 1
Ok, so I have two longs and I want to count the total number of binary 1's in both of them.
It seems that there should be a direct way to do it in Spin, but it escapes me...
In my particular problem the result is between 0 and 8. (Chess bitboard)
I'm thinking that a look with the Spin "bitwise encode" operator will be the fastest method of doing this.
But, I have a feeling that I'm missing something...
Anybody see a simple way to do this?
  • CJCJ Posts: 470
    edited 2008-08-30 02:35
    it would just be a tight loop in assembly
    mov sample, temp1
    mov temp2, #32
    mov temp3, #0
    loop: shr temp1, #1 wc
    if_c add temp3, #1
    djnz temp2, #loop:
    the result will be in temp3
    Parallax Forums - If you're ready to learn, we're ready to help.
    edited 2008-08-30 03:08
    In Spin, try this:
    PUB Count(sample)
      repeat while sample
        result += lookupz(sample & %1111: 0,1,1,2,1,2,2,3,1,2,2,3,2,3,3,4)
        sample >>= 4
    It chunks the long into 4-bit blocks and adds the results from a pre-computed lookup table for each of them.
    'Still some PropSTICK Kit bare PCBs left!
    Post Edited (Phil Pilgrim (PhiPi)) : 8/30/2008 3:27:42 AM GMT
  • CJCJ Posts: 470
    edited 2008-08-30 03:11
    nifty!
  • rokickirokicki Posts: 1,000
    edited 2008-08-30 04:35
    If you don't expect too many bits to be set, you can use:
    r := 0
    while x
       r++
       x &= x-1
    edited 2008-08-30 06:29
    I was going to suggest,
    n := 0
    while x
       n++
       x := x - |< (>|  x -1)   ' encode decode knock down bits
    but x &= x-1 is much niftier. There is also,
    x := (x & $55555555) + (x>>1 & $55555555)
    x := (x & $33333333) + (x>>2 & $33333333)
    x := (x & $0F0F0F0F) + (x>>4 & $0F0F0F0F)
    x := (x & $00FF00FF) + (x>>8 & $00FF00FF)
    x := (x & $0000FFFF) + (x>>16)  ' x now is the bit count
    Tracy Allen
    www.emesystems.com
  • RaymanRayman Posts: 16,383
    edited 2008-08-30 10:33
    Thanks! Great ideas. Now, I just have to figure out which is fastest...
  • MikeKMikeK Posts: 118
    edited 2008-08-30 13:28
    You can unroll Phil's loop to remove the loop overhead. You'd end up with 15 instructions, since you don't need the last shift.
    Post Edited (MikeK) : 8/30/2008 2:14:50 PM GMT
    Rayman,
    If you do unroll my loop, create an array of bytes in the DAT area and index them, instead of using LOOKUPZ, to save memory.
    Tracy,
    Wow! A log n solution. I knew there had to be a way but couldn't quite get there. Guys, if you haven't yet taken the time to understand Tracy's second method, do so now. It's a work of art!
