Propeller ASM Memory Dumper
This object dumps the Propeller main RAM in hex and ASCII, all in assembly. There is no control, it just dumps everything in one shot. The minimum baud rate is 9600 baud at 80MHz, because of the 14 bit PAR register. I did not want to make a control long or two to keep it as small as possible, so the following and only dumping to pin 30 are limitations. Adding this would require more spin, more ASM to parse it, and vars.
Enjoy!
P.S How should I post things like this? A new thread, just the OBEX, or in the Completed projects section?
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
Enjoy!
Channel: #propeller
