Forum Server Error in '/' Application.
Sapieha
Hi Paul Baker.
I will get "" View Active Threads·"
And I ony get "Server Error in '/' Application." from Server
Look on·attachment
Nothing is impossible, there are only different degrees of difficulty.
Sapieha
Post Edited (Sapieha) : 8/29/2008 1:46:15 PM GMT
Look on·attachment
Sapieha
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
Parallax Engineering
As a general rule, I don't recommend using active threads. Even for someone like me who is on the forums alot, the number of unread messages can reach into the thousands. View active threads compiles a list of all unread messages in all forums and displays it. When it does work, it takes minutes to compile this information, and as you noticed it frequesntly won't work at all.
If you really want to use this forum feature, I suggest going into all the forums you don't read and click on the "Mark this forum·read", narrowing down the number of mesages needed to be compiled down to only those forums you are interested in reading.
Paul Baker
