Problem with parallax GPS module
Dear all,
I am currently doing a project on GPS, which i have mentioned before in the forum. Yet, I met a problem and i would like to seek help here.
I have connected the GPS module to the BS2PX module. I·run the demo source but shocked to discovered that my module seems out of order. It kept showing the message "Error: No response from GPS Receiver Module". It's true that no satelites should be found as i am working in the lab, yet i can't even get the hardware information of the module. I wonder if i·made any mistakes, I have tri-checked the wiring and confirm that there isn't any problems. Do i have to expose the module to clear sky in order to get the hardware information?
bbnqond
bbnqond
Thanks for your quick reply.
So, what can I do? Do i have to edit the baud rate of the code to 19200? But the GPS module's baud rate is 4800.
bbnqond
T4800 CON 188
which is used (indirectly) to set the incoming baud rate to 4800. As you can see in the Manual, 188 is the code for the BS2, 4800, 8 bit, no parity, true. The corresponding code for the BS2PX is 813 (lower on the same page).
