Duraband PVS 1970 monitor Video Interfacing to the Propeller
Hi everyone,
I've got Duraband PVS model 1970 Car DVD player with dual monitors. It has a round video input plug on the monitor
it is PAL/NTSC. However, the video input is not a S-Video plug, it has 9 pins in a round configuration similar to s-video
It looks like this...
QUESTION:
Does anyone know the pin mapping to VGA so I can hook it up on the Propeller demo board
VGA ? Or maybe, where I can find it ?
This connector looks similar to a 9 pin video-in and video-out connector as shown here...
http://pinouts.ru/Video/radeon_vivo_pinout.shtml
But, On my connector there is a 1 pin size space between pin 8 & 7 as shown above.
I would like to hook this type monitor up to my Propellers VGA connector, but I don't know how.
Can anyone offer any help ?
Thank you for your help and suggestions.
Areal
I have a tree growing out of my head, but
what do you expect ? I'm a programmer.
QUESTION:
Areal
I did a Google search and found this on a user forum. I do not know if it will help or not.
Use this info with caution, as I do not know if it is accurate.
Whit+
Post Edited (Whit) : 8/29/2008 1:58:36 AM GMT
Ua... It's been a while since I worked with video.
QUESTION:
Can I hook it up to the propeller ? Will it work ?
Would I need to use the RCA instead ? Or what ?
Could I hook up a seperate 12v source with the correct amp level and just input from the Propeller RCA into video in ?
or would two much voltage/current backflow on the video line to the Propeller ?
Looks like the Monitor is pulling 0.83 amps. (12vdc @ 10Watts)
Thanks !
Post Edited (Areal Person) : 8/29/2008 3:34:39 AM GMT
