Question about BoeBot Basic
Hi guys!
·· I tested everything out indiviually and now I am focusing on my IR Detectors and IR emitters as well as soundPal.· I understand in order to preform BS2 commands they are not a part of Boebot basic. So, I downloaded the BS2 Objects so I could have serial and pulse in and out, etc. needed for my next experiments.·
I did the following:
Load in BoebotBasic.spin
Move BS2_Functions to BoebotBasic folder
Add OBJ· BS_2 Functions to the Pink ObJ section.
Load Ram (probably not neccessary)
Load EEprom
get in PST terminal mode on com4
reset Propeller.
At this point, I expected to see a "BoebotBasic version blah blah blah!"
But, it was as if the terminal was not working again.
Any ideas what I have done wrong???
Thanks in Advance.
Load EEprom
reset Propeller.
Thanks in Advance.
You actually have to modify the BoeBotBasic interpreter to add new statements to it. It's not quite as hard as it sounds, but you do have to
know how to read and program in Spin.
2) The BS2 function object is pretty big. If it's too big, it uses up all the memory that's left and there's no place to store the Basic program.
What kinds of functionality do you want to have? There's built-in support for IR object and distance detection already.
To add soundPal support, the interpreter would have to be enhanced by adding new statements.
When you recompile BoeBotBasic, you have to make sure the "console" I/O pins are set appropriately in the serial I/O routine start call.
They're either set to xBeeTx/xBeeRx or bootTx/bootRx in the source code. The copy you have may be set for use with the xBee transceiver.
Post Edited (Mike Green) : 8/29/2008 1:33:24 AM GMT
I am just trying to get the little feller where he can navigate without bumping into things and falling off of things.
You can already use the PING))) and the IR emitters/detector for navigation and avoiding bumping into and falling off things.
The only piece that's missing is the soundPAL. When you've mastered everything else, let me know and I'll make you a special version with the ability to use the soundPAL.
Print it out, scribble notes on it. It's not that many pages.
TEST the PING
Go Right 45 degrees
Go Left 45 Degrees
Go Backward
Go Forward
It is quite a lot of fun. I also changed the code from Left=1500 and Right=1600 to the oposite. I imagine that I had the things wired up wrong. But, it is working now. Gotta Love it!
