A question about capacitors used with the DS1307 Real Time Clock.
Hey all,
I'm planning on using the DS1307 real time clock (RTC) and I noticed it requires two 12.5 pF capacitors. Anybody know what kind of capacitors these should be? Ceramic? or what? I'm concerned that if I pick the wrong kind, it will be more susceptible to thermal fluctuations. Any suggestions?
thanks,
Mark
thanks,
Mark
My confusion stems from page 188 of the StampWorks Manual, version 2.1, in "Using a Real Time Clock." There, it shows the capacitors as being external, but the DS1307 datasheet shows the capacitors as being internal and says nothing about adding other capacitors to the outside of the chip.
Anybody know what is the correct situation?
thanks,
Mark
The load capacitance of the 32.768kHz cystal should have an internal load capacitance of 12.5pF, but you shouldn't be adding any additional cap.
Reference:
http://www.fuw.edu.pl/~pablo/s/docs/ds1307.pdf
Beau Schwabe
IC Layout Engineer
thanks,
Mark
