Quick FET question — Parallax Forums
Quick FET question
BasilBasil Posts: 380
edited 2008-08-28 23:19 in Propeller 1
Hi All,
Just want to check something.
I am currently revising my altimeter board design.
Currently I am using a small N channel FET to interface to the prop, follwed by a higher current P channel.
This was done because I couldn't find a P channel which could drive ~10V @ 6-10A from a 3.3v output.
I have discovered this product. The fairchild FDW2508P, which is a P channel dual FET with Rds of ~20ma and gate threshold of -0.5V typical, -1.5V max
I noticed these values are very close to those on the N FET im current using (Fairchild FDV301) so Im thinking the new FET will interface directly to the prop?
If someone could shoot me down or confirm my Suspicions that would be great.
Alec
-Alec
My our page
    edited 2008-08-28 23:03
    If you need to switch significantly more than 3.3V on the high side, you still have to use an nMOSFET, NPN transistor, or other driver to control the pMOSFET's gate. This is because, even when the Prop output (if it were applied to the pMOSFET's gate) is high, it will still be enough lower than the pMOSFET's source voltage (10V in your case) to turn the transistor on. There just isn't a way to switch the transistor off without bringing the gate to within 0.5V or less of +10V.
    Remember: the gate threshold is always spec'd relative to the source voltage — not to system ground, which the pMOSFET won't "know" anything about because it's not applied to any of its pins.
    'Still some PropSTICK Kit bare PCBs left!
    Post Edited (Phil Pilgrim (PhiPi)) : 8/28/2008 11:21:42 PM GMT
  • BasilBasil Posts: 380
    edited 2008-08-28 23:11
    Ahhh ok then. Do the same rules apply to N FETs?
    Thanks Phil
    -Alec
    My our page
    edited 2008-08-28 23:16
    Yes: the gate threshold is always spec'd relative to the source voltage.
    Ok [noparse]:)[/noparse]
    Thanks for the prompt answer
    -Alec
    My our page
