Bit masking on WAITPEQ
In the case of WAITPEQ what would be the bit mask for 10
Is it 1010 or is it 1000000000
considering the example has
waitpeq(%0100, %1100, 0) 'Wait for P3 & P2 to be low & high
·- Ouch, thats not suppose to be hot!··
Michael King
Application Engineer
R&D
Digital Technology Group
Michael King
R&D
Paul Baker
10_0000_0000 = 512 = 2^9.
A series of masks for the pins 0 through 3 would be:
0001 = 1 = 2^0
0010 = 2 = 2^1
0100 = 4 = 2^2
1000 = 8 = 2^3
What Paul is doing is using SPIN shortcuts to shift a single bit over X times, and OR'ing that with other single bits shifted X times.
That's the "<" operator above, followed by the number of shifts.
Set a bit to a 1 and you've impacted the pin associated with that particular bit, one bit per pin, for a total of 32 bits and 32 pins!
If you want pins 1 and 2, then it's this:
0110 = 2 + 4 = 6.
The addition is like an OR, in that adding single bit values (powers of two) together sets those bits in the mask.
0100
equals
0110
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Post Edited (potatohead) : 8/28/2008 10:22:25 PM GMT
