now mount SD and MMC and SDHC
Hi, All.
I took the awesome sdspifasm.spin as a base, and modified it to use the mounting scheme from elm-chan.org. It can now mount MMC, SD, or SDHC cards. I've tested it on all three types with raw data block access. I can not test the FSRW FAT16 routines on the SDHC, though, since I do not have a card reader which supports the HC version of SD cards and the card did not come formatted as FAT16. Could someone please try it out for me?
I used sdspifasm as a base because it was the fastest version which still had all the mounting logic in SPIN. It will be trivial to port this code to the sdspi.spin and sdspiasm.spin versions, but slightly more tricky to port it to sdspiqasm.spin [noparse][[/noparse]8^)
lonesock
Piranha are people too.
lonesock
are you telling us that, with SDHC, the Prop might be able to utilize SD cards up to (what's the limit?) 32Gbytes? Is this what I'm hearing?
[noparse][[/noparse]8^) That I am. FAT16 still has the 2GB limit, of course, but for raw access (or multiple partitions), yep. (And if I understand correctly, the 32GB limit is in only the 2.0 spec, not any HW limitation. Well, there are price limitations as well
lonesock
But, silly question, has anyone yet found 2GB to be a limit? I mean, even at 1MB/sec (which the Prop cannot get to right now), that's more than a
half-hour of continuous reading or writing.
-tom
I'm getting raw writes at ~5sec/MB (over about 4 different cards). I hope to improve this by using the multi-block read/write commands, but haven't tried it yet (and it also requires larger buffers on the propeller [noparse][[/noparse]8^(. My application will be recording data at almost max for several multi-hour sessions. But I do admit this is an unusual case. I am planning to have a 1GB FAT16 partition up front, and use the remainder of the SDHC card as raw data storage. The user can "export" a given session to the FAT16 partition for easy recovery on their PC.
lonesock
@tom: Hmmm - FAT32 [noparse][[/noparse]:HUGE-SMILE:]
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style
Isn't there a way to read raw data from an SD card, with no file system on it, under Windows. Like the dd command in Unix/Linux. Would be great for big data logging tasks.
