Can Simple_Serial Object do 9600 baud at 5Mhz clock? — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2008-08-30 23:31 in Propeller 1
My Propeller is running at 5Mhz PLL1x.
When I try to send any string using the simple serial object, the cog hangs.
Any ideas?
www.fd.com.my
www.mercedes.com.my
  • CJCJ Posts: 470
    edited 2008-08-28 12:10
    I think that is too slow for 9600 as simple serial tops out at 19200 at 80Mhz
    Parallax Forums - If you're ready to learn, we're ready to help.
  • AleksAleks Posts: 52
    edited 2008-08-28 12:32
    can you up the PLL to somewhere around 8 or 16?
    ~Some men see things as they are and ask "why?"
    I dream of things that never were and ask "why not?"~
  • tpw_mantpw_man Posts: 276
    edited 2008-08-28 13:02
    I think that you would have to do at least 40MHz because 19200/2 = 9600. So half the clock rate at 80MHz(40MHz) would probably be the least you can do.
    I am 1011, so be surprised!
    Advertisement sponsored by dfletch:
    Come and join us on the Propeller IRC channel for fast and easy help!
    Channel: #propeller
    Server: irc.freenode.net or freenode.net
    If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
  • RsadeikaRsadeika Posts: 3,856
    edited 2008-08-28 13:40
    Try not using, 5Mhz PLL1x, in other words, use the internal oscilator, and see what happens. That way you will have checked both conditions, if it hangs, then I would check the code.
    Ray
    edited 2008-08-28 13:56
    If you're actually communicating with an external object, which is the only assumption I can make given your use of the simple_serial.spin, I can advise you that communication is more efficient with the use of an external oscillator, simply due to the way the two are broken down. In the Prop Manual it suggests using an external oscillator for accurate timing due to the inaccuracy of the internal oscillator. Again, pick up your speed via the pll mode, and if you can't get it working check your code or switch to FullDuplexSerial.spin. Maybe you can give us a little more information about what you're communicating with?
    edited 2008-08-28 14:05
    A few months ago I was experimenting with Extended_FDSerial.spin, and using the internal oscilator, I had no problems with 57600 BAUD. I could not go above that, so when I used the external oscilator, then I was able to get up to 240600 BAUD, with no problem. When using the internal oscilator, it did not occur to me to go the other way, like using, lets say 9600 BAUD. I was pretty impressed with the stability of the internal oscilator, maybe I was just lucky, anybody else try that.
    Ray
    edited 2008-08-28 14:13
    Or I could just have a bad oscillator. Either way, its only a line of code to change to check either one, so go for both. If it works, it works
  • william chanwilliam chan Posts: 1,326
    edited 2008-08-28 14:33
    My application is simple.
    I just want to send some strings to my Serial LCD.
    FullDuplex serial seems like an overkill and it takes up one extra cog.
    Why is simple serial so slow?
    Simple things are usually faster...
    www.fd.com.my
    www.mercedes.com.my
    edited 2008-08-28 14:38
    If you're using the 2x16 Serial LCD offered on the Parallax website then you can download my Serial_Com object in the object exchange
    obex.parallax.com/objects/356/
    It has an LCD object I coded within that uses a slightly modified simple_serial.spin to run.
    edited 2008-08-28 18:47
    That object requires 80Mhz clock. My propeller is only running 5Mhz clock......
    If I set RxPin to -1, will FullDuplexSerial still start another cog?
    www.fd.com.my
    www.mercedes.com.my
    edited 2008-08-28 18:49
    can't you just change pllx1 to pllx16 to compensate? that would explain why your program is running so slow.
    edited 2008-08-29 00:33
    I can't run faster than 5Mhz because the Propeller is powered by AAA batteries!
    Looks like we need a "serial transmitting only bit bang assembly" object soon...
    Would it be difficult to write such an object?
    www.fd.com.my
    www.mercedes.com.my
    edited 2008-08-29 01:15
    In the Object Exchange, you'll find a 4-port full duplex serial driver that should be able to run at 5MHz. It adjusts for the system clock speed. For transmitting, you should be able to handle 9600 Baud easily. You can disable the receive side by specifying -1 as the receive I/O pin.
    edited 2008-08-29 02:23
    But what I need is only half a port(transmit only), not 4 ports and preferably does not use a new cog.
    I think Simple_Serial is slow because it uses spin.
    Can it be easily converted to assembly?
    www.fd.com.my
    www.mercedes.com.my
  • TimmooreTimmoore Posts: 1,031
    edited 2008-08-29 04:42
    To convert run pasm you need a new cog. I expect to get to 9600 at 5Mhz you need pasm, this means (5000000/9600)/4 instructions per bit. I wrote the 4 port driver and optimizes the standard fullduplexdriver. It also uses very little overhead if you dont run the ports, i.e. it runs 1 port with 1/4 CPU that it runs 4 ports. So it should need 1/8 cpu to run just tx on 1 port. I haven't done the calculation for min cpu speed for 1 tx at 9600 but the tx loop is about 112 instructions (for 8bits) which should be enough for 9600 at 5Mhz.
    edited 2008-08-29 06:40
    Tim,
    Are you saying that the 4 port driver will use less battery current than the FullDuplex driver?
    If yes, it would certainly help my batteries.
    www.fd.com.my
    www.mercedes.com.my
    edited 2008-08-29 06:53
    william, no they both would be the same. To handle tx they continously poll a memory location to see if there is anything to tx. The 4 port uses less instructions to send a byte so it can support 9600 at a lower clock speed, but once it sends a byte it then polls for the next byte.
    If you wanted that cog to reduce power when there is nothing to send you would have to change something. They easiest way I can think of is to use a spare pin to signal the tx cog and have the cog wait on that rather than poll the memory location.
  • AleAle Posts: 2,363
    edited 2008-08-29 07:16
    Or you can poll at regular intervals. If you send full 16 chars or 32 for 2 lines every time, you can make it poll every 10 ms or so and send all at the same time. Maybe you should retouch the code a bit to customize it for sending 16 or 32 chars (or whatever you need) at once from a HUB memory buffer every 10 or so ms. That way the program is waiting loads of time.
    edited 2008-08-30 05:39
    Can I use a pin in port B (unused port) to signal the Serial COG to start transmission?
    Which line of the object code should I change?
    www.fd.com.my
    www.mercedes.com.my
    edited 2008-08-30 07:28
    Look in fullduplexserial.spin for this code
    transmit                jmpret  txcode,rxcode         'run a chunk of receive code, then return
                            mov     t1,par                'check for head <> tail
                            add     t1,#2 << 2
                            rdlong  t2,t1
                            add     t1,#1 << 2
                            rdlong  t3,t1
                            cmp     t2,t3           wz
            if_z            jmp     #transmit
    This code, reads the tx queue and checks that whether the head and tail of the queue are the same and if so jmps to transmit, i.e. if head and tail are the same then the tx queue is empty. So the pasm cog will spin here when there is nothing to transmit. You want to insert a waitpeq for a pin you pick. Then in the tx spin routine you want to set the pin to be an output pin and set it to 1 when you add something to the queue.
    Then back in the transmit code you need to reset the pin when the tx queue is empty.
    You need to be a bit careful in the order of setting/reseting the pin and adding/removing from tx queue since the spin and pasm cogs will be running in parallel.
    edited 2008-08-30 14:11
    Can I use INB[noparse][[/noparse]0] as the signaling pin?
    www.fd.com.my
    www.mercedes.com.my
    edited 2008-08-30 14:21
    The hardware for the "B" I/O doesn't exist on the current chip.
    There's no "B" wiring from cog to cog. INB / OUTB / DIRB don't connect to anything.
  • hippyhippy Posts: 1,981
    It's very easy to write a PASM routine which takes a byte in PAR and bit bangs it out at 9600 baud the stops itself. That can easily be extended to looping, reading a character from hub and sending whenever there's something available.
    I pulled this from the I2CMonitoring stuff I did ...
                  mov       OUTA,pinMask
                  mov       DIRA,pinMask
    GetByte       rdbyte    getByt,PAR WZ
        IF_Z  jmp       #GetByte
    SendByte      xor       getByt,#$100
                  shl       getByt,#1
                  mov       count,#10
                  mov       timeout,bitTim
                  add       timeout,CNT
    SendBit       shr       getByt,#1 WC
                  muxc      OUTA,pinMask
                  waitcnt   timeout,bitTim
                  djnz      count,#SendBit
                  mov       getByte,#0
                  wrbyte    getByt,PAR
                  jmp       #GetByte
