Propeller IDE 1.2 objects & CASE limitation — Parallax Forums
GiemmeGiemme Posts: 85
edited 2008-08-28 19:02 in Propeller 1
Hi All
I found following not documented limitation in the Propeller IDE 1.2
- you cannot have more that 256 PUB/PRI objecs in one .spin file
- you cannot have more that 64 CASE in one PUB/PRI objects
Regards
Gianni
  • BradCBradC Posts: 2,601
    edited 2008-08-28 10:01
    Yes, there are more limits that that also..
    8 Nested blocks (IF/Repeat/Case)
    32 Objects
    16 ELSEIF
    I've only hit them when really pushing things past practical limits [noparse]:)[/noparse] (ie not actually in real use but code to stretch the limits of the compiler)
    Pull my finger!
  • RaymanRayman Posts: 16,378
    edited 2008-08-28 13:45
    Yes, I was rudely informed of that 8 nested block limitation via error message while writing a Chess code...
  • hippyhippy Posts: 1,981
    edited 2008-08-28 15:17
    The '255 methods only' is a limitation of the current bytecode design.
    The others seem to be restrictions imposed by the PropTool; fixed size arrays for holding the nesting information ? It would be nice if nesting could go deeper as I've run into that problem a few times, particularly with large Case statements. For a 256 Case variant, the solution is to nest Case statements ...
      case n & $F0
       $00 : case n & $0F
               $00 :
               $01 : etc
       $10 : case n & $0F
               $00 :
               $01 : etc
       $20 :
  • jazzedjazzed Posts: 11,803
    edited 2008-08-28 15:30
    The smaller but harder to read solution is to replace "CASE ..." with a string of "IF N == VALUEn"
    This is smaller for each individual IF (on average) and does not require special cases.
    --Steve
  • GiemmeGiemme Posts: 85
    edited 2008-08-28 18:52
    Regards
    Gianni
    I'll second Hippy's nesting suggestion. Even if there were no CASE limitation, it would be a good idea, since it probably just runs faster.
    'Still some PropSTICK Kit bare PCBs left!
