Parallax GPS
does the Parallax GPS work with the Propeller Proto board? Also, how does it compute the heading? Does it actually have to be movig?
I'm new to this stuff! Help is much appreciated.
Yes, the GPS Module is compatible with the Propeller Proto Board. It calculates heading based on the current coordinates in relation to the previous reading. Because of this it needs to be moving to calculate the heading accurately. More expensive GPS units use a separate compass for this purpose.
Parallax Engineering
I think the Parallax GPS module is 5V compatiable. So, you need to be sure to supply it with the 5V DC power supply. Also on the serial output you may want to put a 1K resistor to limit the current into the Propeller pin. I haven't set this up myself with the GPS module, but I know in general this should be done on 5V devices.
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
In general, should a resistor be used for serial outs to the propeller?
www.tdswieter.com
Paul Baker
