questions about signals
i have several questions concerning signals and displays,
is it possible to take an rca signal and convert it to vga and vice versa?
when i look for a display to buy, what should i be looking for and what is manditory?
if a display has a touch screen add on·with the 4 leads, can the propellor read this and display a vga signal at close to the same time?
and finally,·does·anybody know·of ·displays about the size of a 4x6 notecard that are compatible with the prop for farely cheap?
insofar as a display goes, if you mean you're looking for some kind of a simple system just to output information and debug programs, it's fairly cheap and easy to use a TV that has an RCA style input jack. There are some ready-made objects for outputting to a TV that I've found good for a beginner to start working with. Wiring it to your Prop requires just a few output pins and some resistors and maybe an RCA jack you can get at Radio Shack.
A display that is 4x6, on the other hand, sounds more like an LCD you're looking for. Maybe if you're a little more specific about what you want and why you want it, people here can come to your rescue.
good luck,
Mark
It might be the Information Age but the Eon of Ignorance has yet to end.
