Emic speech board to amplifier — Parallax Forums
Joe FishbackJoe Fishback Posts: 99
edited 2008-08-27 14:07 in General Discussion
·I have an Emic speech board that is connected to small 2" 8 ohm speaker. The speaker is connected to the SP- and SP+ pins. The volume is low, no matter what I do. I would like to connect an Emic speech board to an amplifier.
The Parallax instructions talk of a Pin named "AOUT". Is this where I connect an amplifier? ·Do I connect a wire to the GND ? ·The instructions say to "that the AOUT pin must capacitively coupled to the load", what does this mean? Any diagrams or information would be helpful.
Joe Fishback
······ Joe Fishback
-Robots are my friends-
    edited 2008-08-26 16:03
    mounting the speaker in a box will dramatically increase the output try a thin cardboard box first to see what i mean
  • uxoriousuxorious Posts: 126
    edited 2008-08-26 18:57
    Have you tried adjusting the volume on the EMIC? Here's my code for a BS2, EMIC, and TSL230. When the run button is pressed, the light level from the TSL230 is read and announced through the EMIC. I had the same issue with volume so I did two things: 1) As skylight suggests, I mounted the speaker in a pill bottle and the volume doubled easily. 2) I increased the volume to max on the EMIC. Sounds great now. Sorry, no pictures of the setup
    ~~ dRu ~~
  • ZootZoot Posts: 2,227
    You can tie AOUT to a small amp (like an LM386) if you want some serious volume. But a proper speaker enclosure will *always* go a long way to making sound output sound better and increasing volume.
    See this thread: http://forums.parallax.com/showthread.php?p=632642
