Is thre a better way to code this..... reading 5 pings and converting the resu
This Code works but it seems a bit bulky and does take a bit of time to process. I'd appreciate any ideas on how to make it work better.
It reads 5 pings, converts the distance from to a letter A-I. which correlates to an Image on my PINK, visually indicating how close objects are.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
[b]PUB[/b] PINGs | pinkrange, val ,index
range[noparse][[/noparse]0] := ping.Inches(PING_Pina) ' Get Range In Inches
range := ping.Inches(PING_Pinb) ' Get Range In Inches
range := ping.Inches(PING_Pinc) ' Get Range In Inches
range := ping.Inches(PING_Pind) ' Get Range In Inches
range := ping.Inches(PING_Pine) ' Get Range In Inches
'waitcnt(clkfreq / 10 + cnt) ' Pause 1/10 Second
pointer:= 0
[b]repeat[/b] index [b]from[/b] 0 to 4
LCD.gotoxy(Index * 4, 0) ' Position Cursor
LCD.decx(range[noparse][[/noparse]Index], 3) ' Print Inches
[b]if[/b] Range[noparse][[/noparse]index] > range[noparse][[/noparse]pointer]
Pointer := index
[b]IF[/b] Range[noparse][[/noparse]index] > 80
Val := "I"
[b]ELSEIF[/b] Range[noparse][[/noparse]index] > 32
Val := "H"
[b]ELSEIF[/b] Range[noparse][[/noparse]index] > 28
Val := "G"
[b]ELSEIF[/b] Range[noparse][[/noparse]index] > 24
Val := "F"
[b]ELSEIF[/b] Range[noparse][[/noparse]index] > 20
Val := "E"
[b]ELSEIF[/b] Range[noparse][[/noparse]index] > 16
Val := "D"
[b]ELSEIF[/b] Range[noparse][[/noparse]index] > 12
Val := "C"
[b]ELSEIF[/b] Range[noparse][[/noparse]index] > 8
Val := "B"
[b]ELSEIF[/b] Range[noparse][[/noparse]index] > 4
Val := "A"
XB.dec (Index + 1)
XB.tx (Val)
DGSwaner
dat
len byte 4,8,12,16,20,24,28,32,80,65535
repeat i from 0 to 9
if range[noparse][[/noparse]index] < len
quit
val := "A" + i - 1
I haven't tested it, but I would think that you could simplify all of your elseif to something like this...
IF Range[noparse][[/noparse]index] > 80 Val := "I" ELSE Val := "A" + Range[noparse][[/noparse]index]>>2▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
Thanks I'll give that a try when I get home.
DGSwaner
