Hitachi Accelerometer Module
Hi I just got my propeller kit sent all the way to the tip of africa to play around with, with a ping))) and·the accelerometer·module. I rigged up the accelerometer to the propeller proto board as specified, 220 ohm resistors·in series with·all the signal lines, downloaded the object from the obex site, fired it up and it's not working, the X, Y and Z values are never set,·clk, dio and cs pins are toggling. I can read the zero G line... I think there could be something wrong with the·timing, maybe it's not designed for a 5mhz clock, ADC not getting what it wants on the accelerometer side,·or maybe I need better signal conditioning. Has anyone had a similar problem?·I'm a novice, and I'm not sure how to debug this·even if I had·an occiliscope, which I don't.
I'm using Vss and 5v to power it... any ideas???
Could not get the ping))) working either, maybe I need different circuitry, pull up/down resistors, not sure. Either that or the hardware is faulty.
Got servo's to move... and LED's to flash... but that's it... nothing's going in...
*scratches head*
Thanks.
SolderHead
*scratches head*
Thanks.
SolderHead
You do need the 1K on the signal line... and then go over your set up again and check all of the pin assignments in the code.
It is probably not the component or the Prop. It's probably not the object.
to protect the prop pin you need about 560 Ohms... it isn't likely you have damaged anything.
As a last option, turn everything off for a while... then try it again.
