Wanted: Manual download for the HYDRA SD MAX CARD?
Hi All,
I'm trying to learn about the use of SD cards and thanks goes to Mike Green for pointing me toward the documentation of the HYDRA SD MAX CARD. Problem is, the download link for the manual that goes to the HYDRA SD MAX CARD only provides a sample of the manual and not the full documentation. I found this a little odd since Parallax is usually quite generous when it comes to tutorials and downloads and such. Is there another source for downloading this manual? Or is there some reason why Parallax would want to make me buy the entire Hydra system just so I can learn how to use SD cards?
thanks,
Mark
It might be the Information Age but the Eon of Ignorance has yet to end.
thanks,
Mark
You don't need a Hydra to use it, though; one could argue that the price could be worth the SD card, manual, and driver CD's by themselves, and you could still use the adaptor in other setups either by buying a card-edge slot or by soldering wires directly onto it and running them for example into the open I/O pins on the Demoboard.
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
Mark
