Open a door with a servo or stepper motor help.
All,
I need some help finding the hardware for a home control program.
It will be comparing the inside temperature to the outside temperature and humidity. If the outside temp and humidity is below a set value and the inside temp / humidity is above a preset level I want to open the attic access door,·turn off·the AC,·and turn on the whole house attic fan. When the inside temp / humidity drops below a preset level I want to close the door and turn off the fan. I already have the sensors in place.
The door is a light weight 3 foot wide by 2 foot high door. I do have a pair of·revolution revloution servos I can use but lack the hardware necessary to control this door. Does anyone have an idea and know of a source for the hardware?
D. A. Wreski
D. A. Wreski
- Stephen
