alternator charging
I came across this web page showing how to use a automotive alternator to generate electricity.
http://www.dangerouslaboratories.org/altcharge.html but I would like to control this via a basic stamp.
I thought of using a digital rheostat·but none I've seen can handle the amperage. So how can I do this ?
Post Edited (firewater) : 8/25/2008 1:24:33 AM GMT
With an amperage circuit, the stamp would be able to maintain an amperage output by increasing Pulsout/PWM to the·rotor windings beyond·break-even point, while the load exsists. The stamp could also be programed to trickle charge·the battery over an extended period.
- Stephen
Something circa 89-95 GM would be easiest IMO, the "CS" alternator, available from 80 amps up to 130. There is one connector and an output wire. Connect "S" to the output, ignore "F" and "P" and connect "L" to a 3-4 watt bulb (192 is normal) and then to posistive. This excites the alternator, so you MUST have it connected, and you MUST have resistance in there. If you really wanted to make it compact, just wire a resistor to the output terminal. You will need to juice the alternator before it will start charging, to energize the field coils. So just keep it connected to a 12v battery.
So if you use an internally regulated alternator, you only need one wire to make it work, the output wire. Much, much simpler than that hack fest they have there. In fact they go on and on about how unsafe it is and how you have to babysit it. I have no idea why they would do this. If you are not going to have a battery, you could probably hook up a small 12v motor with a hand crank or something to energize the fields. That or get a small 12v battery, or a just a bunch of AA's, you only need to kick the fields before they will take over.
Also, keep in mind the power curve of the alternator when selecting pulleys and power sources. Alternators dont really make any power below 2500 RPM, and thier peak is usually much higher. If you buy a reman one, it will come with a test sheet, which will give you a good idea.
Again, I dont know what you are doing, but automotive alternators dont make very good generators for wind or "renewable" energy sources because of thier active fields and high RPMs. Consider motorcycle alternators, they are usually perminant magnet.
in my opinion that is doomed to failure! the internally regulated alternator if hooked to a substantial battery bank
will never be useful for the following reasons.
1. the hp required to drive it is substantial and without control over the charging you are forced to compromise
between gearing it down enough to have the hp to drive it when the battery is low, and driving it fast enough to provide for
low rpm when the battery is nearing full charge.
2. the cs130 is a dreadful machine for the diy'er to work on, the oem regulator is very poor for charging true deepcycle batteries
3. the life expectancy is going to be short if you ask for max output, and have enough hp to drive it.
4. there is no provision in an automotive alternator for temperature compensation, so you will either cook your batteries
or undercharge them.
so the link addresses some of these issues by compromising the automatic nature of a regulator,, you are the regulator with that
setup.
take a look at a balmar controller such as the mc612 and it will become clear what is needed and why it is needed, and next it will become clar
that a microcontroller could be used to do what they have done. depending on how good you are with your design and what it is you want to do will determine your success.
you might want to study how an automotive regulator works, it is a pwm control scheme (analog) and i see no reason one could not impliment
some digital control into it.
just such a controller is on my list of modules to produce using the bs2
bob g
Dream it, design it, engineer it, build it, and
do what is necessary to make the damn thing work!
Electrical Polarization Process
Amp Inhibiting Circuit
WFC U.S. Patent Validation Report
U.S. Patent Application; S/N 6/302,807 Filed Sept 16, 1981
Natural Water Hydrogen Generation System
Page 18
"Other amp restricting circuits are,
also, applicable such as applying a variable (0-5) volts unipolar pulse frequency across the
armature field-winding of a de-regulated alternator functioning as a pulse-voltage frequency
generator, as so illustrated in Photo Exhibits 11B, 11B1, and 11C."
Large file be very patient:
http://www.waterfuelcell.org/ForumPDFs/International Independent Test Evaluation Report.pdf
Doing so will let all the factory smoke out, and it can not be replaced!!!!!!!!!!!!!!!...Next a " DO-LOOP "or a " GOSUB-RETURN "
W/ an " IF-THEN-ELSE" statment will control the dutycycle% in the "PULSOUT" statment........If you need some more info or help w/ something,Drop a post reply,,I try to checkin the FORUMs every night...............___%WMc$___out__!!!!!!!!!!!!!
