Output a 1mhz 'clock' signal via BS2
I messed up a few of my Atmel AVR chip fuse settings and it was recommended that I can fix if I can feed it a 1mhz clock signal.
Is it possible to use my BS2 to output a 1mhz pulse?
- Stephen
"Because a hammer works better at removing nails." - lol
And there's not as much surface area with a hammer in case you miss...
Spaceman Spiff,
a 74HC14 with a 1MHz crystal may be·a simpler solution...· If it doesn't need to be 'exactly' 1MHz you could fudge with a 555 or even a 74HC14 for that matter.
Beau Schwabe
IC Layout Engineer
That being said, I dont know, but I didnt think the stamp could do that fast, if you have a 555 timer, which any electronics scrap box should, it can be done.
