LCD with Basic Stamp II
Hello,
I have a little problem...i have an Arobot and i would like to add LCD with it. I cnt find any ones that would go with it...
Could annyone recommend any LCDs which could go with it?
thanx
Visit: www.vbnoobs.co.uk
thanx
- Stephen
I am still not shure if would go with my Arobot circute board.
http://www.parallax.com/Store/Accessories/Displays/tabid/159/CategoryID/34/List/0/Level/a/ProductID/50/Default.aspx?SortField=ProductName%2cProductName
as this is the serial version of the LCD and only requires 1 I/O pin. In fact any of the serial LCD's should work.
It's a royal PiA to get those parallel drive LCD's working from the ground up. I've done it with all sorts of controllers and every time it takes a long time to get them talking. Especially if you do not have an O scope.
A wise man told me; "All electronics are made to work by magic smoke.
Don't ever let it out as it's·very difficult·to get it back in."
The only thing i don't get is how do i solder wires so it works. Or do they come with wires too?
try here for help on soldering or read the manuals that came with the parts you plan to use.
- Stephen
